78 CJ7 258 Engine Questions! (Lots of PICS!) - JeepForum.com
post #1 of 4 Old 09-09-2013, 05:27 PM Thread Starter
78RenegadeCJ7
1978 CJ7
Im new to CJs, first time CJ owner I should say. I drive a built XJ and such so I know a good bit about those. Bought this CJ and drove it home. Just now getting around to fixing some stuff and had a couple of questions and concerns regarding the engine. Its the single barrel carb and looks to be stock, I dont know much about them nor what a factory fresh cj engine looked like either. Anyway here is the engine bay....
My first concern is the PCV grommet and valve, ordered one from NAPA and it is there waiting on me, but does it go straight to the carb and thats it?
2nd question....WHERE IS THIS SUPPOSE TO GO?
3rd question is this suppose to be pinched off like this? i dont know what it is called
4th question is this suppose to go somewhere or just leave it plugged?
5th question.. what would mount here? another carb?
6th question the thing in my hand by my finger? is it suppose to be cut off?
7th question... where does this line from the diff suppose to go?
8th and final question... would you say this is the stock breather? and where does the round end clamp looking thing suppose to sit?
78RenegadeCJ7 is offline
post #2 of 4 Old 09-09-2013, 05:44 PM
walkerhoundvm
1981 CJ8
Whoo boy, you been bubbafied!
1. Yes, the PCV valve goes to a manifold vacuum source on the carb. The other side goes to you canister purge port.
2. That part will plug into your air filter housing. Well, maybe not the one you have, but the OEM housing anyway.
3. That's your air injection tubes, part of the original emissions equipment on your CJ. A previous owner bisected and pinched those. If you're in an emissions-free area, I'd leave it as is and focus on some other aspects of your engine for the moment.
4. Dunno, but I'm guessing it's been bubbafied.
5. That's a mount for your throttle control bracket. It's just a bracket that helped align your throttle cable to the carb, so it was a straight pull when you hit the gas.
6. I think that's also part of your air injection system...or maybe EGR. Not supposed to be wide open, but chances are it's been hacked somewhere else to compensate. More info from other members soon.
7. That connects to the top bolt securing your radiator to the grill. It should have a clip on it that will allow you to tack it under the bolt.
8. Could be. That ring connects to a duct that collects hot air from around your exhaust manifold. Its purpose is to provide warm air during warm up when the environmental air isn't warm enough. There's probably a vacuum source on the other side that closes the flapper when your engine is warm enough, at which point you'll revert to cold environmental air. The engine runs best when the air temp/engine temp is in harmony and the fuel vaporizes effectively. Not too cold so it pools, and not so hot that it's too vaporized.
Good luck, you ain't the first who's had to tackle this sort of hack job
walkerhoundvm is offline
post #3 of 4 Old 09-09-2013, 08:24 PM
seabass1858
1983 CJ7
I got tired of my engine compartment. I figured on my cj7 since I have a 1976 vin tag on the firewall that I would snatch that 1983 computer and emisssions out. I left the air tubes that connect to the air cleaner. a before and after of what my engine compartment looks like after a little over a month of owner ship.
seabass1858 is offline
post #4 of 4 Old 09-10-2013, 12:58 AM
Tyger78
Lookin' good, keep it up. I can't wait to rip my front end apart to clean things up.
I've done lost my mind...... mind.... mind.... mind..... mind..... what a silly word.
Tyger78 is offline
