78 CJ5 wining /Grinding / chruning / loud vibrating noise from the engine - JeepForum.com
post #1 of 3 Old 07-21-2009, 02:00 PM Thread Starter
new cal shooter
1978 CJ5
Started my CJ5 yesterday after some brake work, had a Very loud grinding / humming / churning sound when running, so I quickly turned it off, checked fluids, all good, starter was cool, solenoid was cool, so I tried again, same noise, so I again turned it off, then turned the ignition to the "ON" position noise was there in full force. was not the heater blower motor, was coming from the drives side, finally someone told me to try my wipers, they actually worked!
So all this noise came from the Washer fluid pump! Unreal how loud it was and vibrating! Disconnected the ground, its secured, any problem with leaving the hot / positive wire connected and no ground? it's mounted in a plastic reserve jug, but don't know if its still drawing power when jeep is on?
new cal shooter is offline
post #2 of 3 Old 07-21-2009, 02:48 PM
scottymac62
1979 CJ7
Sounds like your wiper switch is stuck (pushed in), and is activating your pump all the time. You may have a bad switch or just need to pull out on your switch a little and see if your pump still runs. You can also pull the pump connection off the back of your wiper switch. I think it's the yellow wire.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 3 Old 07-21-2009, 07:59 PM Thread Starter
new cal shooter
1978 CJ5
excellent, attempted to push / pull switch, stops when i push it in, but the goes on again when I release it, thanks!
I have a loud ticking noise in the engine kcfire64 Jeep CJ Forum 8 11-07-2008 04:05 PM
LOUD LOUD whistle noise dblock16 Jeep CJ Forum 14 01-01-2007 08:40 PM
loud noise redflame6 Jeep CJ Forum 4 11-04-2006 06:49 AM
Loud Clunk Noise?????? GADJIT98 Jeep CJ Forum 9 10-19-2004 10:06 PM
grinding noise when I start my engine, HELP ME?! micali Jeep CJ Forum 1 12-10-2001 04:05 AM
