'78 CJ5 vs Tree (Jeep Lost This 1)
| TJ 5.25" Speaker Adapters - NalinMFG | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Smittybilt XRC Front Winch Bumper, Rear Bumper & Tire |
#1 | |
OK, guys... where can I find the best engine mounts available for a 304 in a '78 CJ-5? AND... what is involved in replacing them? Will a floor jack do?
#2 | ||
Well, I just used one under the oil pan of my 258. I put a 2x4 under the pan to spread the weight over the jack to keep it from denting in the bottom of the pan. I lifted it enough to take the weight of the engine off the mounts, removed the nuts/bolts, then lifted the engine higher to clear the mounts. Took old out, put old in, put fasteners in to hold them in place, lowered jack until all was aligned, snugged fasteners, lowered jack rest of the way. Tightened fasteners. Removed jack and 2x4. Now I won't have to keep replacing my oil filters from them getting punctures from the bad mount..
http://www.jeepforum.com/forum/f8/ricks-build-thread-78-cj5-1223197/ |
#3 |
IMO, MORE makes the best engine mounts. They replace everything from the frame to the block.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc... 2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s............... John N |
#4 |
M.O.R.E x 100 worth the $200
#5 |
Thanks!
OK, thanks for the input guys! Looks like I'll go with the floor jack & MORE mounts... they ARE kinda pricey, aren't they!
#6 |
Umm, No they don't !
"Factory block plates must be retained on a 4.2L and acquired for a 4.0L" "72-75 CJ-5 requires slight drilling to install." More makes killer products, But these are over kill. I'd opt for the daystar/prothane poly engine and trans. mounts. At less than $100, It's a great upgrade, + your upgrading the trans mount. Also it leaves you with a $100 bucks to do another mod. |
#7 |
Hmmm... I'll definitely have to look at that, leaves me fix-up or beer $!
Thanks LT-1! |
#8 | |
#9 | |
![]() Yup, My mistake. I read it correctly, But was thinking 258. I'd still opt for the daystar/prothane poly mounts. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
