78 cj5 front wheels dont turn in 4 wheel drive - JeepForum.com
post #1 of 12 Old 12-15-2011, 06:05 PM Thread Starter
njdave
1978 CJ5
front wheels dont turn in 4hi or 4 lo drive shaft turns but thats it. this is my first jeep and 4wd, so iam a little lost. iam hoping its just the hubs? maybe?
njdave is offline
post #2 of 12 Old 12-15-2011, 06:14 PM
skizriz
1978 CJ7
Are the hubs locked?
Hopefully the PO didn't remove the gears from the front diff.
skizriz is offline
post #3 of 12 Old 12-15-2011, 06:20 PM Thread Starter
njdave
1978 CJ5
Yeah hubs are locked. And when I brought her home I changed all the fluids and I don't remember seeing any metal or anything obvious missing
njdave is offline
post #4 of 12 Old 12-15-2011, 06:40 PM
Hashbrown
Blissfully Unaware
Hashbrown's Avatar
1980 CJ7
Broken hub?
Live Free And Don't Be A Dick
Hashbrown is offline
post #5 of 12 Old 12-15-2011, 06:56 PM
98blacksahara
1951 CJ3A
sometimes too much grease can make a hub "stick" or old nasty grease can do the same..
Originally Posted by RubiconRazorbac View Post
Well, I've never eaten a turd sandwich, but I wouldn't have a problem recommending not to try it.:thumbsup:
But I'm sure someone out there will post that they regularly eat turd sandwiches with no problems...
98blacksahara is offline
post #6 of 12 Old 12-15-2011, 08:44 PM
WindKnot
1977 CJ7
That's where I would start; cleaning and rebuilding the front hubs.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 12 Old 12-15-2011, 09:19 PM
lucdog
lucdog's Avatar
1980 CJ5
The entire drive shaft , including the front differentially yoke is turning, correct. What about the axle shafts, where you can see the u-joint at the knuckel?
I assume the Jeep is driveable in 2 wd. Make sure the hubs are locked, place the transmission in netural, on a FLAT level surface, push the Jeep foward or backwards, while watching the axle shafts at the knuckel, they should be turning with the wheel. The same thing can be done by jacking up one front wheel, rotateing it while watching the axleshafts.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 12 Old 12-15-2011, 09:21 PM
lucdog
lucdog's Avatar
1980 CJ5
Including the front diff?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #9 of 12 Old 12-16-2011, 03:42 PM Thread Starter
njdave
1978 CJ5
Ok I checked the axles the drivers side is turning fine but the hub is not locking the passenger side axle is hardly turning. Iam guessing that could be bad. The front diff was checked when I brought it home and it has Amsoil severe duty in it and I didn't see anything missing and there where no metal chips in the old oil. Thank you to everybody who has been responding.
njdave is offline
post #10 of 12 Old 12-16-2011, 03:56 PM
scrappycj5
1976 CJ5
As mentioned before, check to see if the axle u-joints are turning at the wheels. If so, then you have a problem with the locking hubs. either one of them are bad or they need to be removed and cleaned, then re-greased.
scrappycj5 is offline
post #11 of 12 Old 12-16-2011, 04:13 PM Thread Starter
njdave
1978 CJ5
I check the axle ujointa the driver side is turning fine but the passenger side hardly turns,
njdave is offline
post #12 of 12 Old 01-09-2012, 12:57 PM Thread Starter
njdave
1978 CJ5
Yeah hubs aren't working took them apart and cleane them up and nothing. So like I said the driver axle turns but the passenger side doesn't move guess I gotta look inside the diff?
njdave is offline
Did the CJ7 need the wheels locked for low four wheel drive? thesun Jeep CJ Forum 47 12-24-2011 11:13 PM
Front turn signals dont work with lights on longlimb Jeep CJ Forum 27 09-28-2010 05:35 PM
front wheel drive CJ?? what the?? redcj576 Jeep CJ Forum 6 01-26-2008 11:23 AM
New Front Brakes won't let Wheel Turn lhgdale Jeep CJ Forum 13 08-25-2007 05:03 AM
Turn signals turn on but dont blink JDGordon Jeep CJ Forum 6 02-27-2006 05:17 PM
