78 CJ5-304 Holley Carb Question - JeepForum.com
post #1 of 9 Old 09-22-2008, 03:27 PM Thread Starter
Pugnacious
1978 CJ5
Hello all ... I am new to this forum and jeep ownership. I bought a 78 CJ5, 304 smallblock AMC V8 w/ performance high-range cam, Edelbrock Street Performer Intake, Holley 4 barrel 600 CFM carb (re-jetted for the higher altitude, Heddman Headers &
Flowmaster true dual exhaust.
It is running too rich. Many people are telling me the 600CFM carb is too large for the 304. Has anyone had success using this carb, or should I drop down to the 390CFM carb?
Assuming the floats are correct and the jets are correct or close (about 4-5000 ft)... can this 600 be made to work?
Thanks in advance!
Pugnacious is offline
post #2 of 9 Old 09-22-2008, 05:11 PM
dwloop
1976 CJ5
600 Holley is not too big with a mild cam and headers. I have the same setup on a '76 CJ5 and runs very well, gets fairly good MPG (If I don't listen to the sidepipes too much.. ).
I tuned this Holley myself using a vacuum gage and a little patience.
JeepHammer on this forum has some very good infromation concerning tuning the Holley, just search for that.
HTH
Dave
dwloop is offline
post #3 of 9 Old 09-22-2008, 07:23 PM
JeepHammer
Running On Empty...
1973 CJ5
First off, WELCOME!
Glad to hear from another Jeeper!
We'll try to give you answers and information that will make you spend your money a little 'Smarter',
And we will try and help you out with sources and explanations of Jeeps and Jeep related problems.
Please understand I'm not ripping on you.
I know you purchased this vehicle and this is what you were told...
SO,
What I'm going to do is try and clear up some things so you know what you have and what you are talking about so when you ask for information, or need to order parts, you have the correct information.
This happens all the time (I ran a shop for over 20 years and it's REAL common) and I put another 10 years in with companies like MSD, Holley, Blower Drive Service, ect. before I opened my own 'Hot Rod' engine shop, so I've seen this happen time and time again...
Originally Posted by Pugnacious View Post
Hello all ... I am new to this forum and jeep ownership. I bought a 78 CJ5, 304 smallblock AMC V8...
No such thing as 'Small Block' vs. 'Big Block' when talking about AMC engines...
They are all the same external dimensions and where one comes out, another will drop right back in.
AMC engines have 'First Generation', which is 290, 343, 390, and 'Second Generation', 304, 360, 401.
...w/ performance high-range cam,
'High Range' cam is a mistake at high altitudes, and a High RPM camshaft is a mistake in low rpm trail jeeps, and low mid-range RPM street jeeps.
Higher RPM cams don't work well, and aren't fuel efficient at low and mid range RPM's, and most High RPM range cams don't start working well (Efficiently) until you reach about 6,000 RPM, which most Street/Trail Jeepers aren't going to see unless they miss a shift or break drive line parts in a hard pull!
Vic Edelbrock doesn't make a 'Street Performer' intake.
http://www.edelbrock.com/automotive_...lds_main.shtml
They make two or three versions of 'Performer' intakes.
The standard 'Performer' intake is a very good, Dual Plane intake manifold, and will work well with most 300 to 360 CID engines up to about 5,000 RPM depending on engine displacement.
The larger the engine, the sooner it's going to run out of 'Intake'...
The next step up is the 'Performer RPM' intake, which has slightly larger intake runners and a larger plenum and will allow the engine to make power up to about 6,500 RPM, which is about the limit of mostly 'Stock' engines.
These are horrible for 'Trail' jeeps since they don't have very good idle and just 'Off Idle' characteristics.
There is a 'Performer Air-Gap' which again, works great on mid range engines up to about 6,000 to 6,500 RPM depending on engine displacement, but they don't work worth a darn on low RPM 'Trail' Jeep engines.
A 304 CID engine in a Jeep is a 4 stroke engine, so you automatically have to divide by two, since only 4 of the 8 cylinders will charge (have an 'Intake Stroke') on each revolution...
3042=152 Cubic Inches Of Displacement (CID)
Consider even the most well equipped engine will only run about 90% Volumetric Efficiency (VE).
And your engine is using stock 304 heads and running at high altitued through an air cleaner, figure it (liberally!) at 85% VE...
152x.85% VE=129.2 CID per Revolution.
Now, figure your RPM limit on cast iron rods and cast iron crankshaft at 5,500 RPM...
That's 5,500RPM x 129.2 = 710,600 CID per Minute.
Now, to bring that into perspective, 1,728 Cubic Inches in one Cubic Foot.
710,600 1,728 CID = 411.226 Cubic Feet per Minute (CFM)
Since your engine only requires 412 CFM to operate under optimum conditions at 5,500 RPM, why buy a 600 CFM Carb?...
Heddman Headers &
Headers and full duals without a cross over is a VERY good way to have Right/Left fuel management issues.
Do your headers have long tubes?
The longer the tube, the more Torque that cylinder will produce.
If you have the 'Shorties', you might have well stayed with the stock exhaust manifolds...
Not at altitudes of 4 or 5 thousand feet...
'Air' is much thinner, meaning there are less molecules of oxygen in the 'Air' at that altitude.
That means you will need more 'Air' for the same amount of Oxygen at a lower altitude...
So in this case, a 600 CFM shouldn't be too big for proper tuning.
Some things you didn't tell us,
1. Did YOU do the 'Tuning' on the carb, or did some guy/goofball/kid at the 'hot rod' shop that couldn't keep a job at McDonalds do the 'Tune'?
2. Is the carb a 'Double Pumper'?
Or is it a Vacuum Secondary?
3. What is the 'List Number' on the front of the choke air horn?
Assuming your did you own 'Tune',
4. What were the vacuum readings when you achieved the highest steady vacuum for your idle mixture?
5. What is your 'Part Throttle Cruise' vacuum reading?
6. What Jet Size & Power Valve are you running?
7. If you didn't do your own tune, do you need directions on how to tune your carb so it works better?
If so, take the 'List' number on the choke air horn to the parts store, and get some float bowl gaskets and metering block gaskets, and find/beg/borrow/buy a vacuum gauge, and I'll tell you how to tune your carb.
390 would be too small by far at your altitude, stick with the 600 and tune it.
Without question!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 9 Old 09-23-2008, 06:59 AM Thread Starter
Pugnacious
1978 CJ5
Thank you for the replies. Now that I know the 600 is worth the effort, I will get the information asked and post.
post #5 of 9 Old 10-01-2010, 04:22 PM
smitty5224
1980 CJ7
Jeephammer, if you read my previous question please, disregard. I've spent the night reading all of info on the holley carbs. Thanks for the education.
smitty5224 is offline
post #6 of 9 Old 10-01-2010, 04:53 PM
swatson454
1983 CJ7
Pugnacious,
Ignition timing is all too often left out of the equation when performance cams are used. If the cam is large enough to have a noticeably 'lopey' idle, I'd start off with at least 12 to 15 degrees of initial advance.
Then do your best to set up the lean-best idle. If you find that the mixture screws don't change the idle quality at all when adjusted, you either have too much of the transfer slot exposed or the powervalve may be blown. Do you know how much manifold vacuum you have at idle? Most Holleys come with a 6.5 inch powervalve and a lopey cam can activate the powervalve enrichment circuit way too soon, which kills mileage.
If it were mine, I'd run the vacuum gauge into the cab and see how much manifold vacuum it pulls at WOT/max rpm. Then install a powervalve that's maybe a couple of inches above that, 4.5 ish. It's hard to guess at the right number without knowing what cam is in there, so you'll have to do a little work.
I'd focus on eliminating those two things before playing around with the jets.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #7 of 9 Old 04-15-2013, 12:34 PM
77AMCrookie
1977 CJ5
sorry to barge in on everyone, but as i read i see that you have an edel intake upgrade with the holley carb. Is a new intake manifold necessary when switching from stock 2bbl to holley double pumper?
77AMCrookie is offline
post #8 of 9 Old 04-15-2013, 01:23 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
This thread is working on being 3 years old, nice necro post.
To answer your question, YES, you need a new intake to go from a 2bbl to a 4bbl. NO, it doesn't have to be Edelbrock, although they are good ones and the most common.
Not sure why you'd need a double pumper on a Jeep, though.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #9 of 9 Old 04-15-2013, 02:06 PM
Monoco
1979 CJ7
I have a 79 CJ 7 that had a 600 cfm Holley and could never to get it to run right, alway too rich. I ended up replacing it with a 390 cfm Holley rebuilt carb off the internet and it was junk. Could not get the stumble out of it. In the end I got a brand new 390 cfm Holley from Summit Racing. I runs great. I get about 12 mpg. It has flow masters, stock headers and an Edlebrock performer intake with stock cam. Good luck!
Monoco is offline
Holley carb and stock distributor question ElZorro Jeep CJ Forum 20 01-27-2010 03:18 PM
Holley carb-- is this too much? way_of_life Jeep CJ Forum 5 01-18-2010 09:38 AM
Question for JeepHammer concerning Holley Carb genghisman Jeep CJ Forum 0 05-19-2009 11:10 AM
Holley 470 Carb on 258 Bear-Olemiss Jeep CJ Forum 2 04-20-2009 05:32 AM
Holley carb question coyote69 Jeep CJ Forum 4 12-24-2004 01:08 PM
