78 Cj5 232 running probs - JeepForum.com
post #1 of 8 Old 03-06-2013, 10:21 AM Thread Starter
biggsammy13
Hey guys/gals,
First time poster here and new cj-5 owner, Woohoo!!
78 cj5 232 i6 - 1bbl carb
When I purchased the PO said it needed a new carb. But at the time (2months ago) it drove around well (up to 45-50...not much more). Now it dies while driving and won't fire back up. Seems like I'm getting too much air and its choking it out without getting enough fuel.
-replaced fuel filter and air filter
Didn't help.
Disconnected fuel filter and turned the key over, the fuel line didn't push out any gas at the disconnect. So now I'm thinking I have a clogged line.
Cut the fuel line directly after the fuel pump - turned the key on (holy cow there's gas everywhere) - fuel pump works.
Reconnected Fuel pump line and turned the key to on, now there's gas coming out after the fuel filter (weird. That wasn't happening moments ago)
Cj- starts...woohoo!!!
(Let idle for 15 minutes while apply throttle in bursts)
Drive half a mile - cj chokes out and dies...booooo!
Limp back home where it sits now.
I have the stock carb on it and in the back of my mind I'm remembering the PO telling me "you'll need to replace the carb". Any suggestions on which to choose. Oreillys says they can get me a Tomco (opinions)??? Would a rebuild help at all...or should I just break down and buy a new one?
biggsammy13 is offline
post #2 of 8 Old 03-06-2013, 11:49 AM
reeper
1978 CJ5
Not sure I will be much help but I'll give it a shot. Electric or manual fuel pump? No fuel coming out of the line the first time you checked maybe pump is cutting out. Right after I got mine had fuel problems and found the tank to be full of rust.
reeper is offline
post #3 of 8 Old 03-06-2013, 11:56 AM Thread Starter
biggsammy13
Electric fuel pump.
Would the pump stop working while driving? It looked like there was a small filter before the fuel pump (between the tank and the pump) perhaps that is clogged... I'll swap that out.
post #4 of 8 Old 03-06-2013, 12:12 PM
reeper
1978 CJ5
Will stop working if loses power check the wires maybe a bad connection.
reeper is offline
post #5 of 8 Old 03-06-2013, 12:31 PM Thread Starter
biggsammy13
Will do, thanks Reeper!
post #6 of 8 Old 03-06-2013, 06:17 PM
BagusJeep
1981 CJ7
Electric pumps in old CJs are just another fault waiting to happen. There is no telling if it is the right pressure or anything and if you are getting voltage when needed (fortunately many are quite noisy). The mechanical one is about $15 and reliable as long as you put a filter in before it to stop particles damaging the diaphragm.
One thing I do is put in a short piece of clear fuel hose just before the 3 way filter on top of the engine. This is so I can see fuel coming through and whether there is air mixed in. One area of weakness in the system are the fuel hoses on top of the fuel tank.
As the tank was offerred up from below flexible hose was needed at the factory to make the install easy. This hose rots out, cracks and splits and lets air into the fuel line. If you see large bubbles it is these lines and your carb will run poorly and stall on steep inclines.
The Carter YF carb is not a great performer but being a smaller venturi has good response low down and lets the engine develop good torque. It is easy to strip and clean with carb cleaner, reset the float levels etc. Unless it has worn throttle spindles it can be redeemed.
If you want to change to a new carb you have plenty of choice out there, a bit of research is needed first on what will direct fit and what will need an adapter. I prefer genuine Weber as it is shiny and Gucci and works.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 8 Old 03-07-2013, 11:08 AM Thread Starter
biggsammy13
It does tend to stall more on inclines. I'll be sure to check the lines from the tank for a crack.
Thanks for the tip on clear lines pre-fuel filter and carb info
post #8 of 8 Old 03-11-2013, 12:03 PM Thread Starter
biggsammy13
went ahead and replaced the fuel pump this weekend. seems to have resolved all issues. who would have thought this thing wouldn't run without fuel
thanks for the help!
