78 CJ-7 Carb - JeepForum.com
post #1 of 12 Old 10-13-2013, 12:02 PM Thread Starter
2007st1300abs
1978 CJ7
78 CJ-7 Carb
Hi Guys I'm currently trying to source a carb for my 258 I6 . I have it narrowed down to a Weber 38 , but my carb currently uses the intake manifold to choke metal pipe to operate the choke. When I take this carb off can I cap that fitting and run the manual choke setup?
Thanks
2007st1300abs is offline
post #2 of 12 Old 10-13-2013, 08:24 PM Thread Starter
2007st1300abs
1978 CJ7
btt
post #3 of 12 Old 10-15-2013, 07:17 PM Thread Starter
2007st1300abs
1978 CJ7
Anyone?
post #4 of 12 Old 10-15-2013, 07:29 PM
superj
You have a heated pipe choke currently, like an old school v8? You can block it and run a normal choke
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 12 Old 10-16-2013, 12:23 PM Thread Starter
2007st1300abs
1978 CJ7
Yes it does have that system on it. I don't think it really works that good.
post #6 of 12 Old 10-16-2013, 12:28 PM
arkiemurph
Should be able to block it and run manual choke OR electric choke. Just rig up a wire that's hot when your ignition is on.
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #7 of 12 Old 10-16-2013, 03:05 PM
EgulAye
1980 CJ5
I've got the heat pipe style choke on my '78 motor, it works pretty well. But you can go with whatever style choke your new carburetor has. As arkiemurph says, you can put a manual or electric choke on there - your preference.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #8 of 12 Old 10-16-2013, 07:28 PM
BagusJeep
1981 CJ7
Yes, you can.
I have two Weber 38DGMS installed now and it is an easy fit, though you may need to trim the supplied gaskets to avoid obstructing the venturi.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 12 Old 10-16-2013, 08:24 PM Thread Starter
2007st1300abs
1978 CJ7
Ok Thanks for your help Guys!!
Who do you recommend to purchase this carb from?
post #10 of 12 Old 10-16-2013, 11:17 PM
BagusJeep
1981 CJ7
Redline supply all the parts in a kit, the electric choke version being K551-38 buit there is a manual choke kit as well, number escapes me.
For the kit Quadrateceh is about $390 plus shipping, eBay is about $300 plus shipping. You can find cheaper but you must buy Genuine Weber with Made in Spain and the logo cast into the metal, not a rebadged Solex from Weber USA.
However they supply the chrome rectangular filter which filters air and not much else. If you have the original TAC system on your CJ it is worth retaining it and there is an adapter to keep the original air filter which is IMHO much better. If you have a snorkel there is another adapter you can buy which fits to the top and allows a fender mounted filter system and snorkel set up.
Make sure you have the manifold adapter and accelerator linkage kit if you find just a carb.
When you get it check the bolt lengths for the manifold adapter, they are often too short to go through the adapter and the phenolic spacer the BBD had. The spacer helps with heat transfer so worth retaining under the adapter.
post #11 of 12 Old 10-17-2013, 04:40 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Contact Tom at Redline, tell him I referred you, he'll hook you up.
I agree with Bagus, buy the adapter so you can use the factory air cleaner assembly. The dinky filters that come in the kits are worthless, IMO.
Matt
Matt1981CJ7 is offline
post #12 of 12 Old 10-17-2013, 08:17 PM Thread Starter
2007st1300abs
1978 CJ7
Thanks guys, I will contact Tom !!
