'78 CJ 5 V8 T 150 >bellcrank orientation< - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > '78 CJ 5 V8 T 150 >bellcrank orientation<
DIY tube fender kitsAmsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 09-23-2008, 09:58 AM   #1
turbogus
1978 CJ5
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
Greetings all, "Black Betty" my venerable ole CJ spat a clutch pivot ball a couple of weeks back and, as I work 7 days per week, had a local shop replace the entire assy. Got it back yesterday and the clutch pedal will only fully raise to rest position, a couple of seconds after release. Crawled under "Black Betty's" skirt only to find the bell crank appears to be installed backwards with the grease zerk facing forward. I seem to recall it facing aft. Does anyone reckon this could be where the fault lies?
turbogus is offline   Reply With Quote
Unread 09-24-2008, 03:26 AM   #2
John Strenk
John Strenk's Avatar
1976 CJ5
Yes, mine faces aft also. Never could figure out why it did.
This is modified somewhat to fit on a Fiberglass tub but the idea is the same.
John Strenk is offline   Reply With Quote
Unread 09-24-2008, 05:51 AM   #3
HackFabrication
1976 CJ5
Here's how mine went together:
They probably swapped ends with the Z-bar.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Unread 09-24-2008, 08:37 AM   #4
turbogus
1978 CJ5
A lift of the lynch lid to John and Hack Fab. for your kind, quick responses. Between work (7 days) the bike, and my van, I don't know weather to sh@t or go blind. Special thanks for the pics Hack Fab. I see that on my rig the return spring (outer) is not hooked from the release rod to a frame rail bracket as yours is, rather, it's hooked on the ear of the throwout lever and an extrusion from the clutch cover. (Would post pic if I knew how).
Unread 09-24-2008, 10:25 AM   #5
HackFabrication
1976 CJ5
Don't rely on my install (other than the Z-Bar), because I've got a Ford 5.0L/Ford T18 combo that was installed using MORE mounts. Everything had to be Hack Fab'd out of the OEM CJ parts....
