78-86 Heater components in a 77 CJ5 - JeepForum.com
post #1 of 9 Old 03-17-2008, 09:31 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
Will a switch/heater motor listed as working with a 78-86 CJ5 work in a 77 CJ5 with no modification, or will I need to make adjustments to use them?
Any input is appreciated, and I apologize if this topic has come up - I've searched and come up empty.
Thanks a lot,
~Matt
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #2 of 9 Old 03-17-2008, 09:42 AM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Depends. There were two types of heater boxes available in '77.
If your '77 is the "Type 2" heater box which is the version where the back of the blower motor pokes through the firewall then the aswer is YES.
If your heater box is a "Type 1" where the blower motor is inside the cab then the answer is NO.
PhatBasturd is offline
post #3 of 9 Old 03-17-2008, 09:48 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
My blower motor pokes through a black metal plate (flat circular plate) and has a plastic fan attached on the other side. The motor sticks out inside the cab, and the spindle for it goes into the heater box which is inside the cab.
http://tinypic.com/view.php?pic=2ebei6q&s=3
That's the best picture I have from before I took it apart.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #4 of 9 Old 03-17-2008, 10:20 AM
PhatBasturd
1976 CJ7
So the answer is no. It won't work.
You need a counter clock wise (CCW) blower motor and a I think a two speed switch.
Do a search on CCW blower and you will find the part numbers and brands.
post #5 of 9 Old 03-17-2008, 11:17 AM
jp360cj
1977 CJ7
if you're going to buy a switch and motor, then you can use a ccw chevy motor with a rheostat switch. I can't remember the part number and my Jeep's 100 miles away, but search for chevy blazer motor upgrade and it's in one of the threads. the difference over stock is amazing
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #6 of 9 Old 03-17-2008, 11:25 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
Alright, this whole jeep thing is my first foray into working on a vehicle, and it's a learning experience for me. I appreciate everyone taking the time to help a newbie.
I accidentally purchased a 1978 heater switch, so I've already got that. Is there a way I can make my blunder work?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN:IT&ih=009
That is the switch I purchased.
Can I do the blazer motor coupled with that switch, or can I somehow modify the 78-90 motor.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=011
That is the motor I was looking at that is supposed to go with the switch.
Any chance I can make use of this switch in my 1977?
Thanks a ton for all the help.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #7 of 9 Old 03-18-2008, 07:10 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I forget, did 77 heaters have 2 or three speeds? If they had two speeds, then yes you can make it work.
John Strenk is online now
post #8 of 9 Old 03-18-2008, 07:48 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
I never tried the heat before I tore everything out of the JEEP. Now I'm starting to reassemble and I'm looking to get new parts for the electronics and misc. broken pieces.
I'm not sure if it's a 2 or 3 way originally.
If you compare that switch in the eBay auction to this one for the 76-78 on Quadratec: http://www.quadratec.com/Assets/Imag...2/43172-lg.jpg
I noticed that it looks to be the same switch with a 3rd prong in the middle.
If I were to buy the standard 77 heater motor, could I (excuse me if I'm an idiot) snip off the 3rd prong and use the original black plastic plug harness, or just bypass that 3rd prong when wiring it.
All help is appreciated greatly as usual.
Thanks a lot,
~Matt
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #9 of 9 Old 03-18-2008, 07:57 AM
jp360cj
1977 CJ7
They had 2 speed motors. I would assume the 3 speed switches are rheostats, since everyone said they had to install a rheostat for the chevy swap, so I agree that the 3 speed switch should run the 2 speed motor, just use the high and low or high and med. But I would wire it up before final installation to make sure it works and see which one would be the best to bypass.
jp360cj is offline
ID these 3 components? spittoon Jeep CJ Forum 10 01-09-2010 09:25 PM
New steering components mmerlina Jeep CJ Forum 7 11-11-2009 08:01 PM
How many of what components makes a CJ? superkaz661 Jeep CJ Forum 7 03-07-2009 09:46 AM
Steering Components DT5150 Jeep CJ Forum 12 02-22-2008 12:59 PM
258 IL6 Timing Components cj7roaddog Jeep CJ Forum 9 12-22-2006 05:35 AM
