77 wagoneer front axle swap? - JeepForum.com
post #1 of 8 Old 07-28-2011, 09:33 PM Thread Starter
robert1973
1977 CJ7
ive got a dana44 front axle from a 77 wagoneer. Has anyone done this swap and how did the steering set up work/not work. Just replaced the rear axle this week and pulling the front starting in the morning.
ΜΟΛΩΝ ΛΑΒΕ
The Right is wrong and the Left is stupid
robert1973 is offline
post #2 of 8 Old 07-28-2011, 09:52 PM
Havasu Living
1980 CJ7
gonna do a 79 in the front......show me the way oh great one............
80 CJ7 5.0 Dual Exhaust, T176, D300, D30 w/ true trac, AMC 20 w/ ARB 4.56 gears, York OBA, Hydroboost
Havasu Living is offline
post #3 of 8 Old 07-28-2011, 09:58 PM
Daladim
1982 CJ7
I too am working on doing a similar swap. I have a Dana 44 from a 79 Wagoneer. I have already determined that it will be difficult. I have my frame outboarded and ready for the swap, but the lift kit I purchased is made to be used with a Dana 35.
Be advised that the 44 axle tube is wider in diameter than the 35, and so is the area on the differential where the spring mounts. My measurements were 3 inches on the drivers side, and 3.5 inches on the passenger side. Bigger U-bolts are needed for my swap, and some modifications to the spring plates for my suspension kit. I just spoke with a machinist this evening about getting this thing together, so I have no more information than what I have found out so far. I am sure there will be further difficulties I will encounter as well.
Daladim is offline
post #4 of 8 Old 07-28-2011, 11:06 PM Thread Starter
robert1973
1977 CJ7
I have the poison spyder full width axle kit to get the axle mounted. I thought I read a thread somewhere about having to use a different pitman arm to make things work. Hopefully we an get someone who's done the swap to chime in. Am gonna try to get some pics as I'm doing the swap. The tube diameter for these are 2.75" when you get u bolts. I wrapped up the dana44 rear swap today. Can't wait to be done!
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 8 Old 07-29-2011, 07:23 AM
foggybottombob
I have a Scout axle on the front of my 84 CJ7. If you measure from ball joint to ball joint on the inner knuckles of a scout D44 axle and a waggy D44 axle the difference is 1/8". They are almost the same from end to end with the same outers on them. The waggy axle has the pumpkin a little further inboard.
I outboarded the spring hangars and made a tie rod and drag link from DOM. My suspension is SOA. I have the stock CJ pitman arm.
foggybottombob is offline
post #6 of 8 Old 07-29-2011, 08:19 AM
CSP
The web is loaded with documentation on the Wagoneer Dana 44 swap.
The correct pitman arm to use in this swap is the Wagoneer pitman arm as the length matches the length of the steering arms on the waggie knuckles. You'll need a waggie drag link as well.
CSP is offline
post #7 of 8 Old 07-29-2011, 12:16 PM Thread Starter
robert1973
1977 CJ7
Excellent! all I need to track down is the pitman arm then. Thanks
ΜΟΛΩΝ ΛΑΒΕ
post #8 of 8 Old 07-29-2011, 12:39 PM
79jeepincj7
1979 CJ7
And outboard your spring hangers if your not cutting the axle down.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
'76 Wagoneer Front Dana 44 Axle Swap - Help poooorsche Jeep CJ Forum 73 11-20-2015 08:21 PM
1974 wagoneer front axle WMS after cutting down for cj7 Dougyfreshh Jeep CJ Forum 7 05-04-2011 12:15 AM
Possible axle swap d44s wagoneer? others? JeepnBlake Jeep CJ Forum 15 08-25-2008 09:58 PM
79 cj front axle swap cody11ca Jeep CJ Forum 3 11-01-2007 10:05 PM
front axle swap? sacc1001 Jeep CJ Forum 4 08-14-2007 05:59 AM
