77 shoulder belts install help - JeepForum.com
post #1 of 6 Old 09-07-2013, 01:44 PM Thread Starter
Ollie09
1983 CJ7
Going to install shoulder belts in my 77 which came with just lap belts. I had the bungs welded into the rollbar now need to mount to the floor. Does anyone have a picture of how/where the floor mounts should be fastened (retractor reel and belt end)? Tried the search but couldn't find a thread with a picture of the floor ends. Also, did you mount the buckle end in the stock location? Seems to far back.
Ollie09 is online now
post #2 of 6 Old 09-07-2013, 05:21 PM
Patter
1981 CJ5
Pics are in this order. Bung mount, retractor on wheel well mount uncovered, same with cover, female latching receptacle mount.
Good luck.
Had to add the bung on my 81 cj5 also.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #3 of 6 Old 09-08-2013, 06:31 AM Thread Starter
Ollie09
1983 CJ7
Thanks for the pix. Where did you mount the end of the belt? I can' see it in the picture. Is it bolted to the floor right below the retractor? I assume the retractor is mounted to the rear floor riser, correct?
post #4 of 6 Old 09-08-2013, 07:28 AM
ADDZ71
1979 CJ7
I bolted the retractor and secure end using the same bolt.
ADDZ71 is offline
post #5 of 6 Old 09-08-2013, 08:27 AM
Patter
1981 CJ5
Yes. That's what I did too.
Bolted thru the wheelhouse or wheel well.
Bolt pic from wheel side.
Hope it helps. Thx ADDZ71 !
Patter is offline
post #6 of 6 Old 09-09-2013, 02:43 PM Thread Starter
Ollie09
1983 CJ7
Got it. Thanks to all.
