-   -   77 shoulder belts install help (http://www.jeepforum.com/forum/f8/77-shoulder-belts-install-help-1572597/)
Ollie09 09-07-2013 01:44 PM
Going to install shoulder belts in my 77 which came with just lap belts. I had the bungs welded into the rollbar now need to mount to the floor. Does anyone have a picture of how/where the floor mounts should be fastened (retractor reel and belt end)? Tried the search but couldn't find a thread with a picture of the floor ends. Also, did you mount the buckle end in the stock location? Seems to far back.
Patter 09-07-2013 05:21 PM
4 Attachment(s)
Pics are in this order. Bung mount, retractor on wheel well mount uncovered, same with cover, female latching receptacle mount.
Good luck.
Attachment 665744
Attachment 665745
Attachment 665746
Attachment 665747
Had to add the bung on my 81 cj5 also.
Ollie09 09-08-2013 06:31 AM
Thanks for the pix. Where did you mount the end of the belt? I can' see it in the picture. Is it bolted to the floor right below the retractor? I assume the retractor is mounted to the rear floor riser, correct?
ADDZ71 09-08-2013 07:28 AM
I bolted the retractor and secure end using the same bolt.
Patter 09-08-2013 08:27 AM
1 Attachment(s)
Yes. That's what I did too.
Bolted thru the wheelhouse or wheel well.
Bolt pic from wheel side.
Attachment 665921
Hope it helps. Thx ADDZ71 !
Ollie09 09-09-2013 02:43 PM
Got it. Thanks to all.
The time now is 05:40 AM.
