77 cj7 help on id some things - JeepForum.com
post #1 of 7 Old 01-06-2014, 08:17 AM Thread Starter
nwmgnt
1977 CJ7
77cj7 304v8 quadratrac.
(1) in engine bay left fender side there is a relay sitting there, has some red wires going into it 4 posts, with one ground.....its just sitting there, not connected to anything. it is right near midpoint of left fender area where i also find a red wire with a white tracer hanging loose from main wire harness. i need help id this
(2) left fender engine bay, off main wire harness, i find a loose red wire with white tracer has a femal connector on it. anyone know what this is?
fyi-my horn is missing on left fender. i thought relay for horn was under dash. i dont know what these wires do.....
thanks
nwmgnt is offline
post #2 of 7 Old 01-06-2014, 09:06 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Can you post a picture of the items?
John Strenk is offline
post #3 of 7 Old 01-07-2014, 07:51 AM Thread Starter
nwmgnt
1977 CJ7
here is a pic from left fenderwell.
there is a loose red wire with tracer that comes out of the main wire harness here....
and right near there a relay is sitting there with some red wires and a ground....
please help ID the red wire with tracer and what that relay is for....thanks
nwmgnt is offline
post #4 of 7 Old 01-07-2014, 08:11 AM
MoC
Whatever it is, it is not factory and a prior owner did it. AMC did not use connectors or a relay that looks like that. Nor would they have had that many red wires in one location.
MoC is offline
post #5 of 7 Old 01-07-2014, 08:34 AM Thread Starter
nwmgnt
1977 CJ7
since my horn is missing, do you know what wire color goes to the horn?
nwmgnt is offline
post #6 of 7 Old 01-07-2014, 08:38 AM
MoC
The horn is red with a white trace.
MoC is offline
post #7 of 7 Old 01-07-2014, 02:45 PM Thread Starter
nwmgnt
1977 CJ7
moc-
thanks....that red wire wire with white trace comes out of a main harness. that explains alot. i will try to hook up the horn now.
i guess the horn relay then is under dash, and as the previous poster mentioned most likely this relay is added for some reason by po.....
thanks for the help. hopefully i will have a horn soon.
nwmgnt is offline
