77 Cj5 Teardown Update, Help!!! - JeepForum.com
post #1 of 9 Old 10-07-2006, 11:43 AM Thread Starter
NCHornet
Ok y'all, was hoping I would get the tub off today, but things didn't work out just as I had planned. I got everything disconnected from the firewall, got the clutch linkage disconected and so on. I went to pull the body bolts and was hoping since there was minimal rust they would come free, Yeah Right!!!!
What a Stupid design to have an open channel, with captive nuts, for all the dirt and moisture to collect and rot stuff!!! I have just tried the drivers side so far, but 1 just broke, 1 came out, yeah!!, the other two just spin. I think I can get a swazal in there and just cut thru the bushing and straight thru the nut, but then what? If I cut the nuts off how do I remount the body? Is there a way to do it without having to weld?
Also I learned a huge lesson, I crawled underneath and thought I would take off the huge skid plate under the transfer case. Well guess what, that thing ain't just a skid plate, the transfer case is mounted to it!!! Of course I didn't find this out until I pulled the last bolt out on one side and the thing dropped about 3". It was a real pain to get everything to line back up too, about 2 hours worth. Anyway another stupid design. I would sure appreciate any help y'all can give me
Thanks
Kevin/TJ
TJ's CJ5
1977 CJ5 4X4, Soft top
304 V8 project jeep for my
16 year old son and I
NCHornet is offline
post #2 of 9 Old 10-07-2006, 11:51 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Suprise!! Good thing you didn't hurt yourself. It actually mounts to the tranny but either case that sucker is heavy.
I wuld say to cut the bolts and work on the nuts when you can lay the tub on its side. But lets wait for other opinins. Some take a hole saw and cut through the tub to replave the nuts and plug it up later.
John Strenk is offline
post #3 of 9 Old 10-07-2006, 12:00 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That is probably how I would approach it.. and I'd weld the nuts in place too.
BESRK is offline
post #4 of 9 Old 10-07-2006, 12:52 PM Thread Starter
NCHornet
The one in the front corner I don't think you can get to with a hole saw? If the channel is in good shape I think I can use a reg nut and bolt as I can reach it with a wrench from the end of the channel, maybe I will use the hole saw idea for the mounts in the middle. Does anybody know if Lowes sells hole saws for metal? All I have seen are for wood. I need to go get some sawzal blades and thought I would pick one up.
Thanks
TJ's CJ5
NCHornet is offline
post #5 of 9 Old 10-07-2006, 04:48 PM
jeepping
I don't think there is anyway around it without a welder. I just did all my body mounts and all the bolts broke or nut spun. A cut-off wheel will do the trick, make 3 cuts and bend the panel back and weld it back on. I had to do both front (just fwd of the seat), both rear (at the tailgate), and the one under the grill.
jeepping is offline
post #6 of 9 Old 10-08-2006, 04:20 AM Thread Starter
NCHornet
Hey, I like the idea of cutting three cuts and making sort of a door, this would allow me to get to the nuts now and later, then just bend them back down and have somebody weld them up. Thanks for the great idea. Just thinking as I type, can you use this method to get the one all the way up front?
Thanks.
NC/TJ
TJ's CJ5
NCHornet is offline
post #7 of 9 Old 10-08-2006, 05:29 AM
Bard
What I have done in the past is if the bolt breaks or the nut spins is to cut them off at the bolt with a sawzal. It is much easier to take the tub off and then get to the ones that didn't come free. If I were you, I would do it this way, remove the tub, set it on its side or upside down and get everything set for someone to come in and weld everything at once, it will lower your costs and you can plan around it. It will also save you time. Good luck.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #8 of 9 Old 10-08-2006, 03:22 PM Thread Starter
NCHornet
Thanks Bard,
I went and bought some new sawzal blades today.
Kevin/TJ
TJ's CJ5
NCHornet is offline
post #9 of 9 Old 10-08-2006, 05:36 PM
LivesIn10sly
LivesIn10sly's Avatar
That's exactly how I handled mine.
Bryan
Just got rid of the ZJ...workin' on the new CJ project..
'83 CJ-7
33x12.50 Dunlops, YJ tub, Herculiner, black diamond plate, Painless wiring, HEI
...much more to come soon...
LivesIn10sly is offline
teardown/reassembly sanity check spittoon Jeep CJ Forum 6 01-13-2010 08:07 PM
Model 20 T-case teardown. Major issues attworth Jeep CJ Forum 20 07-29-2009 04:15 PM
Stuck w/ T4 tranny teardown issue in middle of restoration! imtheant Jeep CJ Forum 3 10-10-2008 08:11 AM
84 cj7 update gt4660 Jeep CJ Forum 0 02-17-2007 12:31 PM
84 CJ update a84jeepCJ7 Jeep CJ Forum 1 03-14-2006 06:54 PM
