77 CJ5 Crawls when I give it gas - JeepForum.com
post #1 of 3 Old 02-24-2002, 10:24 AM Thread Starter
fickesd
Red face 77 CJ5 Crawls when I give it gas
Seems to idle almost regular but when I step on the gas it just crawls enough to pull it in the garage. It's getting gas in the carb., I've replaced the fuel filter, plugs, distributor cap, rotor and ignition coil cable. The plugs that are brand new just have a real thin film of oil or gas (not sooty). My second thought is that it could be a vacuum leak but all of my vacuum hoses have been plugged since I owned the vehicle. Could my carb. need to be adjusted or rebuilt? Oh yeah I also put gas stabilizer in my tank just in case I had moisture in it.
Any other suggestions? I'm out of ideas without starting to replace expensive stuff.
Thanks,
Steve
fickesd is offline
post #2 of 3 Old 02-26-2002, 01:26 AM
Ralph Curry
Post
How old is your gas? Are you sure it's gas? I have a friend with a garage, and some guy had his car in because it wouldn't run. Turns out somebody put diesel in it, but there was enough gas to almost start, but not enough to run.
You might try getting a small container of gas and bypassing the gas tank. See if it runs better when it gets to the new gas.
Ralph Curry is offline
post #3 of 3 Old 02-26-2002, 03:45 PM
Jeep Daddy
Jeep Daddy's Avatar
Post
When did it start doing this? Before you installed all those parts? If it started after you installed those parts, check your new parts against your old parts. (cap & rotor!!) Make sure you put the cap on right with the plug wires in the correct firing order.
If it happened all of a sudden while you were driving or starting to drive it, there could be a timing chain problem. Although, you have not mentioned what engine it has so it's hard to say what else it might be.
If it has a catylitic converter, that could be plugged. Check fuel pressure by disconnecting the fuel hose to carb and inserting that business end into a bottle and crank the engine for a few seconds. As mentioned before, deisel bad - gas good (LOL)
Check your oil. A guy last week said almost the same thing and found out his oil filter had a big hole in it and all the oil in the engine was gone. Too much friction - bad....
Will it rev up in neutral? does it backfire? does it have good spark? You sure you got the plug wires right? that's about all I can think to check.
Good luck.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
Did they give me a bad icm? mcurcio1989 Jeep CJ Forum 9 02-10-2010 04:32 PM
must give props. nate758 Jeep CJ Forum 15 01-19-2008 10:33 PM
how much should i give for cj5 bsj04 Jeep CJ Forum 5 03-01-2007 06:25 AM
give me some ideas plmoss21 Jeep CJ Forum 12 12-02-2005 06:18 PM
I give up, need help John C Jeep CJ Forum 7 01-22-2005 09:09 AM
