77 304 ignition upgrade - JeepForum.com
post #1 of 8 Old 02-03-2012, 08:28 PM Thread Starter
Bunky67
1977 CJ5
I want to upgrade my ignition on my 77 jeep 304. at first I was going to try and use a motorcraft distributor and GM module. but after pricing a distributor and parts. I came across a HEI unit on Ebay. for $60 shipped. so I'm thinking of going with this instead anyone else used one pf these units?
or have any iput on using Hei over the mptorcraft?
Bunky67 is offline
post #2 of 8 Old 02-03-2012, 08:38 PM
caseman580
1976 CJ7
I just did the motorcraft and msd upgrade in my 76 304. Best upgrade I've done for the money so far. Used the summit unit and followed jeephammers advise on the other stuff. Like I said, ABSOLUTELY no comparison to the prestocrap. I've heard a a lot of bad things about the eBay hei units. No experience myself just what I've heard but I can vouch for the msd. Well worth the money.
1976 CJ7, 304, quadratrac, TH400,
"Real Jeeps have flat fenders for your tools"
caseman580 is offline
post #3 of 8 Old 02-04-2012, 12:14 AM Thread Starter
Bunky67
1977 CJ5
so did you buy just the msd box from summit or the distributor to.
Bunky67 is offline
post #4 of 8 Old 02-04-2012, 04:44 AM
mopar408
1974 CJ5
I've got the Duraspark distributor-GM module-Ford TFI coil and am 110 % satisfied.
If you decide to do it, pm me an email addy and I'll send pics and tips.
I would NOT use one of the eBay wonders, period, paragraph.
If you wanted to do that, I've got an old point-type Delco you can have. At least it won't kill your cam gear.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #5 of 8 Old 02-04-2012, 06:39 AM
caseman580
1976 CJ7
I used the summit 850610 cdi box and the summit g5217 coil, the rest I got from the local parts house. You need to get the msd to motor craft dizzy adapter harness as well if you go this way. And a MUST is good wires @ least 8.5 mm. Think it was I little less than $300 for everything and I was a little hesitant on spending the money but like I said, there is no comparison. Cold start went away, you hit the key it starts. Throttle response is awesome and my mpg is a noticeable difference. I wish I would have done this to begin with, it would have saved me a ton of "tinker" time I've wasted trying to "tune" it in. Jeephammer has a good writeup on this on pre 77 ignition systems. Very easy to do.
post #6 of 8 Old 02-04-2012, 09:35 AM Thread Starter
Bunky67
1977 CJ5
ok so it sounds like dura spark is the way the way I want to go
so now where do I find a distributor?
and. I can come up with thw rest
j
Bunky67 is offline
post #7 of 8 Old 02-04-2012, 11:46 AM
JeepHammer
Running On Empty...
1973 CJ5
*IF* you go HEI off the 'Internet',
Then beware the distributor.
Wrong install heights, wrong distributor gears, 'China' components.
There is no 'Junk Yard' or off the shelf swap for a 'Correct' HEI since Jeep never used an HEI.
You are limited to the offerings from 'Internet' retailers that don't always get things 'Correct',
And they WILL damage your engine.
If you want an HEI, then go with the $300 version from DUI,
People report virtually NO failures with DUI over the 'E-bay' offerings.
If you aren't afraid of a little wiring, you can do a swap to the Jeep/Motorcraft distributor for about $60.
A Remanufactured distributor from the parts stores WILL NOT destroy your camshaft gear, have the correct install height so the gear rides in the correct position on the camshaft,
And it doesn't have the 'Spark Energy' control problems the HEI/clones do.
For a 304, that's a distributor from a '79 Jeep CJ with 304 engine, it will drop right in.
Then you do an upgraded cap, rotor, plug wires so you get the spark energy where it's supposed to be...
See signature line below for those details...
Then you use a GM HEI style module to drive your new ignition, which is pretty simple since you are coming over from a Prestolite system, the wiring is already in place...
Again, see Prestolite upgrade in my signature line...
THis thread http://www.jeepforum.com/forum/f8/ig...jeeps-1302352/
Scroll down to post #4 & #5 and see if this is something you can do...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 8 Old 02-04-2012, 12:58 PM
mopar408
1974 CJ5
look for about a 1980 Wagoneer w/ 360. That's what I bought (ebay) for a buildable core since I was gonna just clean/rebuild/replace parts in it anyway.Also you are SURE to get a compatible dizzy gear that won't kill a cam drive gear that way.
mopar408 is offline
Ignition Upgrade '78-'90 Jeep, TeamRush Upgrade... JeepHammer Jeep CJ Forum 61 02-22-2017 09:47 AM
Next step Team Rush upgrade ignition upgrade tevans59 Jeep CJ Forum 7 03-29-2010 04:39 PM
i need an ignition upgrade for a '76 kw89425 Jeep CJ Forum 32 08-27-2008 02:55 PM
HEI vs TFI Ignition Upgrade emersonjeep Jeep CJ Forum 14 09-22-2006 01:40 PM
Ignition Upgrade TFI or HEI shonuff Jeep CJ Forum 16 09-21-2004 01:11 PM
