'76 CJ7 Temp Gauge not working, Fuel Gauge does work - JeepForum.com
post #1 of 12 Old 07-12-2010, 01:22 PM Thread Starter
AJeep
I have been searching thru the forum to find some help with my Temp Gauge. From all the links I have followed, I see the Temp Gauge is directly, wired with the fuel Gauge. SO my question is, since the fuel gauge is working could it be the temp sensor? I know the motor is getting hot, because when I come to a stop it boils over and when I am moving it stops boiling over. Does this mean the thermostat needs to replaced as well?
Sorry about all the questions, but I just need to get this running so it can get smoggeed. Then I want to get an entire new wiring harness for it, this jeeps wires has been hacked and are so brittle. Its just an old vehicle that needs some attention.
AJeep is offline
post #2 of 12 Old 07-12-2010, 01:28 PM
blackhawk51
1976 CJ5
I'd like an answer/possible solution to this also. My temp gauge worked but fuel gauge didnt, but when I got the fuel gauge working the temp gauge stopped working.
ΜΟΛΩΝ ΛΑΒΕ
My CJ5 Restore and Build Thread
blackhawk51 is offline
post #3 of 12 Old 07-12-2010, 01:52 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Best I can do for ya
Let me google that for you
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #4 of 12 Old 07-12-2010, 01:56 PM
blackhawk51
1976 CJ5
Yeah, I've been meaning to go through and run those tests again, thats the write up I used while doing the wiring and installing the gauges.
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 12 Old 07-12-2010, 02:25 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by AJeep View Post
Iknow the motor is getting hot, because when I come to a stop it boils over and when I am moving it stops boiling over. Does this mean the thermostat needs to replaced as well?
Sounds reasonable. When it boils over is the radiator hot or even warm?
You need to check the fluid level in the radiator as well. It should be up to the top. Make sure there an appropriate amount of coolant in the reserve bottle too. Also, don't use tap water as part of your 50/50 coolant/water mix; use distilled water so you don't introduce minerals into the system which could lead to a clogged radiatior. Or buy a pre-mixed 50/50 coolant/water mix.
It could also be the water pump. If that's not working then the best coolant and thermostat aren't going to help overheating.
Are the belts in good shape? Are they there? Slipping?
Be careful about the engine overheating because that can quickly lead to severe engine damage.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #6 of 12 Old 07-12-2010, 02:38 PM Thread Starter
AJeep
I will check those also, never thought of it being the water pump.
This is gona be a stupid question but how many belts should I have? Im guessing 2?
AJeep is offline
post #7 of 12 Old 07-12-2010, 02:40 PM
walkerhoundvm
1981 CJ8
The temp sensor is an $8 part. To test the sending wire, ground it TEMPORARILY to any ground (pull it from the sensor and connect a wire to the engine block) - run check to see if the temp gauge is registering, quickly unground if so. If not, you have a bad sending wire, if the gauge is running up, it's your sensor. I had the same issue - fuel gauge worked, temp gauge always read low. Replaced sensor and now she behaves.
-N
walkerhoundvm is offline
post #8 of 12 Old 07-12-2010, 04:05 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
It depends on your particular setup and what's under the hood. I'm not familiar with the '76 so someone else will have to chime in.
Some engines use a serpentine belt (one belt drives multiple things) and some use mutiple belts. I suppose there is no AC or air/smog pump on a '76, so probably you'll just be turning the alternator and the water pump.
Ken4444 is offline
post #9 of 12 Old 07-12-2010, 06:54 PM Thread Starter
AJeep
Yes that is correct. Just the alternator and water pump. Its such a simple machine and yet drives me nuts. LOL, Doesnt take me much for that tho.
AJeep is offline
post #10 of 12 Old 07-12-2010, 06:57 PM Thread Starter
AJeep
-N
Walkerhoundvm
Yes it reads low like nothing is happening. That is a simple test as soon as I get home I will try that, Thanks.
AJeep is offline
post #11 of 12 Old 07-12-2010, 07:43 PM
walkerhoundvm
1981 CJ8
It shouldn't take more than a few seconds to start moving up. Have someone in the seat watching if you have to hold the ground. If you leave it grounded for more than it takes to start moving up, you could fry the gauge (so I've heard, but I wouldn't want to test that claim!)
Just be warned that the reading is relative once you get it in order, if the sensor change works. Everyones gauge reads different to some extent even when functional, so keep track of where yours normally reads when warm and cold and how soon it gets warm, etc. A search here will give you some info on other owners normals - mine is between 1/3rd and 1/2 way across the green. It got closest to half way a week ago when it was 95 and I was slowly charging up a steep incline.
-N
post #12 of 12 Old 07-12-2010, 07:49 PM Thread Starter
AJeep
Yes it worked so now I just need to get a new sensor. Thanks for the advice, wish all the projects this thing needs would that easy. Again thanks for the help, Walkerhoundvm.
AJeep is offline
temperature , gauge , CJ , fuel
Fuel and temp gauge not working littleturner76 Jeep CJ Forum 1 04-16-2009 03:52 AM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 01:41 PM
fuel and temp gauge not working stonewallmp5 Jeep CJ Forum 5 04-13-2007 09:12 AM
Temp and Fuel Gauge not working bamakrw Jeep CJ Forum 97 05-17-2005 12:30 PM
temp and fuel gauge not working? aufderheide Jeep CJ Forum 7 02-22-2004 12:03 PM
