76 CJ5 unable to start - JeepForum.com
post #1 of 25 Old 11-04-2013, 06:33 AM Thread Starter
itw69
1976 CJ5
Hello all, I have been trying to track down a fix for my starting issue. My CJ would start and run every time. It sat for a month or so without being started.
Then I went to start it and when I turn the key (fully charged battery) the starter spins but the Jeep wont start. I used an inline spark tester, but it showed no spark at all.
I cleaned the ground on the front of the engine and checked all my wires.
I have installed a new ignition module, coil, solenoid, distributor and starter. I used an OHM meter and have verified that there is 12volts of power making it to the distributor. So, I am a bit baffled as to why the CJ wont start.
I bought the CJ5 already fitted with a 360 V8 installed, so....manuals are not helping me much with this trouble shooting.
If you can help, I would appreciate the input.
Thank you very much.
itw69 is offline
post #2 of 25 Old 11-04-2013, 07:07 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Check the coil.
Matt
Matt1981CJ7 is online now
post #3 of 25 Old 11-04-2013, 08:12 AM Thread Starter
itw69
1976 CJ5
Originally Posted by Matt1981CJ7 View Post
Check the coil.
Matt
New coil was installed as well
itw69 is offline
post #4 of 25 Old 11-04-2013, 08:23 AM
Matt1981CJ7
1981 CJ7
I've returned enough parts to know that "new" means nothing when it comes to CJ parts.
The FSM, or even a Haynes Manual, has a detailed section on ignition testing.
Matt
post #5 of 25 Old 11-04-2013, 08:27 AM
seabass1858
1983 CJ7
Ignition control module maybe or a fuse?
seabass1858 is offline
post #6 of 25 Old 11-04-2013, 11:47 AM
WindKnot
1977 CJ7
Are you still running the stock ignition system?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 25 Old 11-05-2013, 10:03 AM Thread Starter
itw69
1976 CJ5
Matt
I used an OHM meter and have verified that there is 12volts of power making it to the distributor. Which I tested after the coil - so the juice is getting there, but the beast wont start.
itw69 is offline
post #8 of 25 Old 11-05-2013, 10:05 AM Thread Starter
itw69
1976 CJ5
Yes it is the stock system - I used an OHM meter and have verified that there is 12volts of power making it to the distributor. That would eliminate any bad hardware to the distributor, I would assume.....
itw69 is offline
post #9 of 25 Old 11-05-2013, 10:07 AM
Matt1981CJ7
1981 CJ7
Do you have a manual of any sort?
Or are you hoping we hold your hand thru the whole diagnoses procedure?
Matt
post #10 of 25 Old 11-05-2013, 10:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well stock could be points, Prestolight or Duraspark distributor.
Any idea which one you have?
Pictures will help
Also While it's important to have power going into the coil (+) it important the (-) side of the coil is switching. Put your DVM on the (-) points and see it it's jumping up and down when cranking or is it a steady 12 volts or 0 volts...
Just pretend the 360 is a 304 because the ignition systems are similar.
John Strenk is online now
post #11 of 25 Old 11-05-2013, 10:16 AM
LumpyGrits
Are you sure your get'n fuel?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #12 of 25 Old 11-05-2013, 10:16 AM Thread Starter
itw69
1976 CJ5
Matt
I have a manual for the CJ5 and a Wagoneer - since the 360 was used in the Wagoneer and the Cherokee -
I did not ask anyone to hold my hand - I asked for advice and suggestions. If you are going to bust my chops, feel free to move on to another thread.
I have spent many hours troubleshooting this issue. And I am posting my query hoping someone, with some helpful knowledge will read my overview in its entirety and may recall an issue like this.
itw69 is offline
post #13 of 25 Old 11-05-2013, 10:18 AM
John Strenk
1976 CJ5
67 or 76 CJ? 67 manual will be of little help. The Wagoneer manual will be better, what year Wagoneer?
post #14 of 25 Old 11-05-2013, 10:24 AM Thread Starter
itw69
1976 CJ5
LG
yes I confirmed good fuel flow
itw69 is offline
post #15 of 25 Old 11-05-2013, 10:30 AM Thread Starter
itw69
1976 CJ5
Pictures will help
76 Wagoneer book
It has electronic points.
Yes I did confirm the coil function as well - I did get a jump while trying to start it.
I pushed through the casing on the power lead from the coil to the distributor, to verify that power was making it to the distributor. I replaced the distributor thinking the "old" one was dead. But, the problem was not corrected by this action.
itw69 is offline
cj5 , no spark , wont start
