76 CJ5 Tub Removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 76 CJ5 Tub Removal
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 09-10-2010, 09:11 PM   #1
dison001
1976 CJ5
76 CJ5 Tub Removal
Im thinking that the best way to approach my unmollested Cj5 is to remove the tub. I got it running, but every time I touch it another piece falls off. All the work will be much easier. Question is, I've never taken a body off the frame before. Can anyone detail the process? Helpful tips? Thanks in advance. Dave
dison001 is offline   Reply With Quote
Unread 09-11-2010, 05:53 AM   #2
HackFabrication
1976 CJ5
If your CJ's body resembles mine (when it followed me home):
If you don't plan on using the tub: The best way is with a SawsAll, Cutting Torch, and Cutoff Wheels. Start with the front end, and work your way back and down.
HINT: DO NOT THROW ANYTHING AWAY!!!!!!!!!!!!!!!!! YES, I AM YELLING!!! Which you will do after the trashmen have take away that irreplaceable part(s). Bag it, Tag it, take hundreds of pictures before and after. Keep bolts/nuts/clips/etc. with the items that are removed. If you have help, don't have too much help, as they all won't be around when it comes time to put it back together.
The 76 models have a number of things that are NOT available in the aftermarket. Heater parts and cables are difficult to locate. If you anticipate installing a new body:
Then consider updating to the 78-86 heater and gas tank/filler assemblies. I updated the gas tank, etc. But now wish I'd done the heater, as there is so much more support for the later versions.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Unread 09-11-2010, 10:18 AM   #3
dison001
1976 CJ5
unfortunately, the budget doesn't allow for cutting off & replacing. And its not as bad as yours was when it came home with you. I've got some junk appliances that are willing to donate their steel. thanks
