76 cj5 emergency brake stuck - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 76 cj5 emergency brake stuck
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 05-07-2015, 11:05 AM   #1
CollinCJ5
my emergency brake is stuck, I have the wheel and drum off and I'm looking at the e brake spring being compressed. I had to drive it home about 10 miles but the shoes look fine and so does the inside of the drum. I cannot get the emergency brake disengaged from the pedal or from inside of the drum because of rust, i believe. Has anyone had this problem? I really need help! This is my daily driver!
CollinCJ5 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 11:31 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Yup, the cable swells from rust and jams inside the case. You need to figure out which cable has seized. The 3 cables join up behind the drivers seat underneath. You can pull on each wheel cable to see if they move. That is where you can slack them off also.
From experience in the rust belt, if one is seized, usually all 3 need to be replaced.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 11:49 AM   #3
CollinCJ5
How would I remove the cables and would it be safe to not have the e brake attached? I don't use it at all because it didnt work until my friend slammed his foot on the pedal.
Unread 05-07-2015, 12:27 PM   #4
CSP
If the cables are seized just cut them as they have to be replaced anyhow. A cutoff wheel on a grinder or air tool is the best tool for this task.
Your ebrake obviously isn't working, so removing the cables is no different.
CSP is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 12:28 PM   #5
Mike Romain
Look under behind the drivers seat. You will see 3 cables coming together and a looonng bolt to try and fight the adjusting nut off of on one cable. Sounds like the front cable is bad, but it is safer having the cable cut even then having dragging brakes. If replacing the cable I don't mess with that usually rusted round nut, I just use the angle grinder on it.
Mike
