76 CJ5 258 idles kinda rough. - JeepForum.com
post #1 of 4 Old 02-16-2012, 05:52 PM Thread Starter
ShowroomShine
It starts just fine (except for a ground problem once in a while) and runs great while at rpm and does not leak a thing. However, it just runs really rough at idle. The previous owner changed the cap, rotor, wires and spark plugs. Has a fairly new carb apparently as well.
It just idles rough and kinda "pops" (however its more of a sucking sound) at idle.
With my very vague description does anyone have any ideas?
ShowroomShine is offline
post #2 of 4 Old 02-16-2012, 06:03 PM
hp_lovecraft
1981 CJ5
At least for my '77 232, rough idles have usually been caused by vac leaks. Also, the Carter-YF gets easily clogged. When I first got my latest CJ, the idle was cranked super-high to cover up for the fact that it would not idle at all!
The popping might imply the vac leak. Its means the engine is leaning out. Could also be way, way mistimed engine
hp_lovecraft is offline
post #3 of 4 Old 02-16-2012, 10:29 PM
walkerhoundvm
1981 CJ8
My first thought was vacuum leak as well - check all manifold bolts, vacuum lines (PCV, distributor advance vacuum line, etc), carb base screws...
My second thought was a choke plate that isn't set correctly - is it a manual or electronic choke?
walkerhoundvm is offline
post #4 of 4 Old 02-16-2012, 11:24 PM
JeepHammer
Running On Empty...
1973 CJ5
I have to agree, if it pops out the carb, then it's probably lean misfire...
Rebuild carb, use a GOOD fuel filter, and flush the line before you hook up to the carb...
What is your vacuum reading?
Have it running, then spray around intake, carb base plate, vacuum lines, see if your vacuum goes up at any particular spot on the intake run...
Also have a look at the choke, choke problems can cause what you are describing.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
85 CJ7 Idles ok but accelerates rough FDSART Jeep CJ Forum 0 10-17-2011 09:37 AM
CJ starts and idles rough maxonaplane Jeep CJ Forum 4 09-27-2010 11:21 PM
YJ Brake Booster Upgrade - now idles rough TetanusCJ7 Jeep CJ Forum 4 07-05-2009 05:30 AM
75 CJ Idles great, runs rough under load Jeepdoc78 Jeep CJ Forum 3 06-05-2009 01:23 PM
CJ5 idles smooth, runs rough. private Jeep CJ Forum 11 01-27-2009 01:50 PM
