75 CJ5 w AMC 304 - weird start problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 75 CJ5 w AMC 304 - weird start problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 07-12-2014, 08:28 PM   #1
sabbyATL
1974 CJ5
So, I'm back. With a seemingly new problem.
Oh, and I have a 74 CJ5, not a 75. Typo in the thread title. But it does have the AMC 304.
Last weekend and early this week my Jeep drove fine. It's always had a bit of a sluggish start and if the battery cables are loose it sometimes won't start. I say this because on Tuesday we had an issue with it not starting and I went under the hood and wiggled the cable and it started.
Today when we went to start it there was nothing, not even the radio came on. I popped the hood and found the cables to be nice and tight.
I pulled out my multimeter and checked the charge across the battery and it was showing something like 6 and some change.
After a moment I noticed something weird about the ignition coil, which I replaced in late April of this year. I checked the charge to the coil and it was nothing - zero.
The weird thing I noticed about it was that it seemed like it had melted (see pics).
I took the battery to the auto parts store and they tested it and said it was dead dead dead bad bad bad.
So, I bought a new battery and a new coil. I also bought new battery cables because the old ones were a little ratty with exposed threads.
I replaced the cables, installed the battery, and then set to work taking out the old coil.
Let me tell you...that coil was HOT. Blistering hot. And I hadn't run the Jeep since Tuesday. I am not sure how it got hot right there that day.
So, here we have a dead battery and a super hot melted ignition coil. I don't know if that happened when we went to start the Jeep this afternoon or if that was happening on its own or what.
So, I replace the coil.
Went to start it and here is what happens:
1. In Run the dash gets power.
2. In Start it cranks and turns over and catches.
3. It immediately dies after one little engine rumble.
Almost like it has no fuel to keep going, but there's a good quarter tank left. And I turned on the electric pump for good measure. I get the same sequence as above.
I took my multimeter and tested the battery - 12.5V.
Then I turned the starter on Run and tested the positive side of the solenoid - 12.44V
Then I tested the positive side of the new coil - 5.6V
That's all I did because it was getting dark and I had plans.
So, can anyone help me figure out what's going on and I'll go fix it?
This forum has been so much help in the past so it's the first place I've come to.
Thanks!
Jen
20140712_192343_zpsrjvnj0al.jpg   20140712_192348_zpsw9hddcu7.jpg   20140712_192409_zpsujjmlpes.jpg
sabbyATL is offline   Reply With Quote Quick reply to this message
Unread 07-13-2014, 09:37 AM   #2
sabbyATL
1974 CJ5
Can anyone help me?
The current issue is that when I try to start my CJ5 it cranks, turns/catches, and dies after the initial fire. This all started after findino the battery dead and the coil melted. Both are replaced.
Unread 07-13-2014, 10:27 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Is the coil still getting real hot? A short in the alternator can sometimes cause that.
You also might have melted the ballast resistor if yours has such. I would turn the key to run and see what the volts are on the coil positive. The coil gets a different power in start.
I would also try unplugging the alternator to see if it runs.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-13-2014, 10:48 AM   #4
sabbyATL
1974 CJ5
Just felt it - cool.
The ballast resistor looks fine but would it be obvious?
So, assuming I got it right that Run is like Accessory where it gives power to the dash and under the hood but doesn't start the engine then I can tell you that the coil had 5.39 on the positive end.
Unread 07-13-2014, 10:51 AM   #5
sabbyATL
1974 CJ5
Oh, and the carb is getting fuel. Just checked.
Unread 07-13-2014, 10:55 AM   #6
sabbyATL
1974 CJ5
Thanks, by the way. Thanks A LOT!
Unread 07-13-2014, 11:00 AM   #7
Mike Romain
I would unplug the alternator and then see what the coil reads.
Mike
Unread 07-13-2014, 12:13 PM   #8
sabbyATL
1974 CJ5
Ok, sorry this took so long. Was also doing laundry.
And I'll be going to a pup down the street around 3 to watch the finals in the World Cup so I'll have to take another break. I don't really drink so I'll be good to work on it later.
Anyway, disconnected the alternator from the solenoid and tested the coil, showEd 5.41V.
Unread 07-13-2014, 12:29 PM   #9
sabbyATL
1974 CJ5
Ok, here are some readings:
Across battery - 12.37V
Solenoid - 12.36V
Alternator - 12.36V
Coil (alternator to solenoid) - 5.97V
Coil (alternator detached from solenoid) - 5.91V
Unread 07-13-2014, 12:30 PM   #10
sabbyATL
1974 CJ5
Does this mean the solenoid is bad?
Unread 07-13-2014, 12:36 PM   #11
sabbyATL
1974 CJ5
Never mind about the solenoid.
I tested the ballast resistor and found 12.17V on the right side (facing the resistor) and 11.87V on the left.
Unread 07-13-2014, 12:43 PM   #12
Mike Romain
That is good. Now why is that 11.87 not making it to the coil? Could the plug at the coil have gotten burnt too?
Mike
Unread 07-13-2014, 12:49 PM   #13
sabbyATL
1974 CJ5
So, from what I read the ballast resistor should reduce the voltage to the coil, which it appears it's doing. I don't know if going from 12 to about 6 is right but that seems to be what's happening.
I want to reiterate that there IS spark.
The engine does actual start but it just dies immediately after starting. As if there is no fuel to keep combustion up or something. But I can tell you the carb is getting fuel. And I don't know how a fuel problem could be related to the battery and coil having a meltdown.
Unread 07-13-2014, 12:50 PM   #14
sabbyATL
1974 CJ5
The one at the top of the coil?
It's possible. The top of the old could was crumbling away from the heat damage.
Unread 07-13-2014, 01:01 PM   #15
sabbyATL
1974 CJ5
It looks fine to me.
Order of photos is:
Plug on new coil
Inside of plug
Old coil
20140713_135126_zpsguimndf3.jpg   20140713_135234_zpswffywpnf.jpg   20140712_192343_zpsrjvnj0al.jpg
