'75 CJ5 E-Brake Repair - JeepForum.com
post #1 of 15 Old 03-12-2012, 12:23 PM Thread Starter
JeepCocky
1975 CJ5
Hey guys,
Just signed up to the forum and doing research on my other 06 TJ Iím glad I have. I actually just sold of the TJ off and went with a 1975 CJ5. When I looked at the Jeep it had some nice beauty shots in and out, and when I test drove it she felt OLD. I was quickly reminded of how long itís been since Iíve even driving in an antique like this. So we puttered around the neighborhood and it seemed fine to me.
When I got it home (250+ miles away on a trailer) I took it in because it seemed to be running rich. I wanted to do the work on it myself. Itís one of the main reasons for picking up an old CJ5. I was sick of dealing with Engine Codes and chasing an issue. Wanted something I could see working before my eyes. So I took it into a shop here in Austin. Right off the bat, you need a new Carb, new Distributor, wires, plugs, Rust in the filter. 1300 later I still need a new Tank, new e-brake and Clutch replacement) these are all on the verge of going out.
Right now though, Iím in need of replacing the E-brake. Upon inspection the T-bar release handle is busted off but the rest of the components seem to be working fine, although I canít get the pedal to latch and hold. Iíve searched High and low but canít seem to find a schematic. Yeah I know I should pick up a manual and I will. But for right now a simple PDF Diagram would work too. Anything would help.
(1975, Parking Brake, E-Brake, CJ5)
JeepCocky is offline
post #2 of 15 Old 03-12-2012, 12:58 PM
osajus
1980 CJ5
Go to: https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL
Drivers License Number: a123456789012
Schematic is in the repair section
osajus is offline
post #3 of 15 Old 03-12-2012, 01:58 PM Thread Starter
JeepCocky
1975 CJ5
Osajus: Thanks but it just shows an animation of the e-break being pulled and released...
post #4 of 15 Old 03-12-2012, 02:19 PM
osajus
1980 CJ5
From that link, login and select make/model.
Click Repair > Brakes >Parking Brake >Cables >Removal & Installation >Rear Wheel Type Hand Brake >Front Cable
Should show a schematic of the system. Sorry, I can't post photos right now
osajus is offline
post #5 of 15 Old 03-12-2012, 03:49 PM Thread Starter
JeepCocky
1975 CJ5
Thanks Osajus, but unfortunately it's not a hand break, it's a Pedal Break with a t-bar release system.
This is the only Digram I could find. The part # (8.180-1) is what I'm looking for...
post #6 of 15 Old 03-12-2012, 08:09 PM
osajus
1980 CJ5
Yeah, I know it says hand brake but if you follow the links it will show a foot pedal. (http://content.chiltonsonline.com/co...s/85369080.pdf)
Looks like you need an assembly (http://www.jeep4x4center.com/jeep-br...bler/index.htm)
osajus is offline
post #7 of 15 Old 03-13-2012, 10:57 AM Thread Starter
JeepCocky
1975 CJ5
There we go! One little word changes everything in a good search! Thanks Osajus!
post #8 of 15 Old 03-13-2012, 12:48 PM
248107
1983 CJ7
You should be able to post pics at 25 posts.Just saying
248107 is offline
post #9 of 15 Old 08-27-2013, 08:47 AM
alfsr78
1973 CJ6
Jeep Cocky, did that assembly work? I am in the same boat on my '73 and from what I could see the bolt pattern at the firewall is the same, but on mine there is not a bolt at the top at the front, but a bolt at the side. 76' is the year Chrysler took over jeep and that seems to be when this was changed.
Please let me know if this worked for you.
Thanks,
Al
alfsr78 is offline
post #10 of 15 Old 08-27-2013, 10:19 AM
CSP
Chrysler did not take over in '76. Jeep was still AMC at that point.
Yes, there were lots of changes made in the '76 model year, but it had nothing to do with Chrysler. One change was the ebrake pedal assembly. You'll want to find one from a '72-75 and the various classifieds on these forums as well as searching locally like via craigslist will be necessary to find the correct parts. They aren't sold as new that I'm aware of.
CSP is offline
post #11 of 15 Old 08-27-2013, 10:26 AM
Newbjeep
1972 CJ5
While we are on the subject of the intermediate cj5 can some post a picture of how the brake is supposed to look with the release and all of that thanks.
Newbjeep is offline
post #12 of 15 Old 08-28-2013, 08:53 AM
alfsr78
1973 CJ6
Hey Newbjeep,
Here is a picture of mine. As you can see the handle is broke off, but this is the best I can do. This model the handle attached to a cable as in the diagram posted earlier. Good luck in finding one.
alfsr78 is offline
post #13 of 15 Old 08-28-2013, 08:58 AM
alfsr78
1973 CJ6
Sorry CSP, my mistake on the Chrysler take over. This is the year they started using the Mopar ebrake assembly made by Chrysler.
alfsr78 is offline
post #14 of 15 Old 08-28-2013, 09:58 AM
CSP
No, that's the first year that you can find a ebrake assembly at a dealer with a Mopar part number now assigned to it. It doesn't mean that Mopar made the part for Jeep. If AMC dealers were still around you'd find an AMC part number for that part.
Mopar didn't ever come into the picture for Jeep until late 1986. Yes Jeep used lots of parts made by other companies, but that isn't one of them and not much was used from Chrysler other than Torqueflite transmissions starting in the 80s.
CSP is offline
post #15 of 15 Old 09-10-2013, 04:33 PM
tineyhairs
1975 CJ5
know what your going thru. my 75 needs the same thing to pass inspection. just bought it to rebuild it for my grandson. he is a jeep nut along with his dad. I had a 78 golden eagle. 3 sp. 6 cyl. he remembers the good times we had as father and son with it. wants to do the same with his 3 boys in his 02 yt.
tineyhairs is offline
Jeep CJ7 brake repair-caliper alisa65 Jeep CJ Forum 2 11-26-2011 06:12 AM
FNG brake problem. Dash E-Brake light on - pedal is softer then a teddy bear Dudman5703 Jeep CJ Forum 6 06-23-2011 06:53 PM
Best way to repair a nicked brake line (pic) tevans59 Jeep CJ Forum 13 04-19-2011 07:19 PM
Front Drum Brake pic's for repair 1976 CJ7 Tigerpaw Jeep CJ Forum 11 11-30-2009 06:26 AM
Brake Pedal wear repair T18A Jeep CJ Forum 4 10-10-2007 01:04 PM
