75 CJ-5 Brake Light Anomaly - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 75 CJ-5 Brake Light Anomaly
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 02-12-2009, 09:43 PM   #1
Fletch8672
1975 CJ5
Disclaimer:
I know it's probably been run into the ground and I've researched it on here before I asked but couldn't find anything pertaining to my problem. Therefore, "I'm sorry" in advance....
Problem: Brake Lights don't work when pushed in. All other lights & signals work (front & rear, high/low, hazards) but when I push the brake pedal... nothing. When the lights are off... no brakes. When I turn on the lights....no brakes.
I've changed all bulbs, checked/replaced all fuses, replaced hazard & turn signal relays and still nothing. I'm thinking the brake switch but I don't know where it's at nor can I find it. I can take pictures if that'll help and post them here.
Any & all help is GREATLY appreciated.
Present: 96 XJ ~Black~ , 75 CJ-5 ~Blue~
Past: 95 YJ ~Bright Mango~ , 96 XJ ~White~, 72 CJ-5 ~Baby Blue~
Remember: Owning A Jeep is a lot like having Herpes, sure it may act up from time to time but you'll never get rid of it...
~Black Jeep Society~
Fletch8672 is offline   Reply With Quote
Unread 02-12-2009, 09:58 PM   #2
GreenCJDan
1975 CJ5
It does sound like the switch since the turn signals and the flashers work. The brake light switch on a 75 is located just north of the brake pedal. If you follow the pedal mechanism up you will see two wires coming out of a box connected to the pedal lever. These can be tested with a volt meter. The most common problem would be a lack of a good ground. See if you can find the switch, and see if the wires are connected properly, this is a good starting point
GreenCJDan is offline   Reply With Quote
Unread 02-12-2009, 10:48 PM   #3
Coiz
Coiz's Avatar
1979 CJ7
This is from a 79 but I assume they are the same. When you press the pedal, the white plunger springs out connecting the contacts allowing current to flow to the lights. The entire switch screws in and out for adjustment. See if the plunger moves freely and it should have continuity with an ohm meter when extended.
Mike
My build thread
Coiz is offline   Reply With Quote
Unread 02-12-2009, 10:57 PM   #4
Oily
No ground issues with this switch. It just allows the hot wire current to pass through.
As Coiz mentioned, it is adjustable.
Oily is offline   Reply With Quote
Unread 02-12-2009, 11:15 PM   #5
only in a jeep cj
I think that on the 75 CJ, it was a pressure switch on the brake lever pivot pin (down and to the left of Coiz picure). 2 wires going to it.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 02-13-2009, 12:26 AM   #6
CJ258
1974 CJ5
My '74 has a really different switch. It attaches to the push rod and likes to flop around and swing downwards. I replaced it with an OEM unit from Kragen that failed a few months late. The one I have now is from NAPA and mount on the column with a lever on the brake pedal so that when depressed the switch lever activates the lights. I could get the plug out of the Master cylinder or I would have used the press. switch.
CJ258 is offline   Reply With Quote
Unread 02-13-2009, 11:53 AM   #7
Fletch8672
1975 CJ5
I checked the brake pedal, per Coiz's picture, but there was nothing that looked like that around the pedal, so I followed the pedal thru the firewall to the brake fluid reservoir.
Then the 2 hoses on the left of the reservoir to what I think is the brake switch
There are no other wires around or even long enough to reach down there.
Unread 02-13-2009, 12:00 PM   #8
incynr8
1974 CJ5
the switch on the combination valve is for your brake warning light.
incynr8 is offline   Reply With Quote
Unread 02-14-2009, 07:44 AM   #9
Oily
Did the brake lights ever work ?
The switch assembly may have come loose and is hanging. If not you may not have had one but, you should have the wires/plug for it. There would be two wires and you can make a connector and just plug one into the other to see if the brake lights work.
Unread 02-14-2009, 06:32 PM   #10
Fletch8672
1975 CJ5
Still no lights and I've checked almost everything. I'll crawl under again tomorrow and check for hanging wires but I can't understand why there's no wire going to the brake switch?!?!~ Just puzzles me...
Unread 02-14-2009, 07:13 PM   #11
crusty75
1975 CJ5
The switch on a 75 is located above the brake pedal, near the pivot under the dash. The switch is powered from the turn signal switch. Follow the wires from your turn signal switch under the dash until you come to the "pyramid connector". You will know it when you see it, it is a perfectly descriptive name.
If your switch is missing, go to NAPA and get a new one, they are about $15. you should find the power wire hanging loose somewhere from the pyramid connector, and the wire that leads back to the lights should be hanging near the brake pedal somewhere. Both wires use common spade connectors. After you get the switch installed, if the new switch doesn't work, pull the pyramid connector apart, and clean the corroded contacts. You should be good to go, providing you have good wiring at the rear of the jeep.
Edit to add: The switch looks nothing like the pic posted above, that is for a post 76 jeep. The switch looks like a small rectangular box, with two spade terminals. It slides over the pivot, and is held in place with a cotter pin. (or in my case, a finishing nail)
But what do I know? I'm old.
crusty75 is offline   Reply With Quote
Unread 02-14-2009, 08:18 PM   #12
6leafclover
1974 CJ5
mine on the 74 looks like the one above on the pedal assembly except its mounted lower so that the pedal arm itself hits the switch, the one on the block with the brake lines is for the warning light and has nothing to do with brake lights in the rear just the light on the dash, i dont even have that switch on mine as the warning light was optional in 74 and maybe other years
6leafclover is offline   Reply With Quote
Unread 04-02-2009, 09:03 AM   #13
mckenziemc
1974 CJ5
Me Too! But I think I know how to fix it.
I have the exact same problem. I am 90% sure it is the Spartan turn signal switch on the steering collum. I have traced power from the brake light switch on the peddal assembly to the wiring harness that goes to the turnsignal switch and verified that power does not come back. I am looking for a source for the switch now. I will let you know what I find out.
mckenziemc is offline   Reply With Quote
Unread 04-02-2009, 09:18 AM   #14
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
When the wire in the combination/proportioning switch in that photo is disconnected, that implies the brakes failed so the previous owner disconnected the warning light so a cop wouldn't tow him or to sucker the poor next owner. That switch sets off a red light on the dash when the pressure isn't right or when there is a leak.
It looks like the wire harness piece to that safety switch is missing, I can see the connector in the first photo in the bottom right I think. From that connector there is an 18" piece that runs down to the switch.
As far as the brake light switch goes, I have to lay on my back and get really twisted up to even get a glimpse of mine...
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 04-02-2009, 09:27 AM   #15
mckenziemc
1974 CJ5
Wong Year I think
It is different on 74 and most 75 CJ's Unless his jeep has a GM steeringAcollum. In 76 AMC switched to a GM steering collum. So our (pre 76)brake lights go from the switch on the pedal set to the turnsignal switch which is a bolton/aftermarket made by spartan which combines and powers the brake lights and turn signals then from the turn signal switch the wires run to the tail/brake lights.
