74cj5 steering problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 74cj5 steering problem
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-18-2015, 09:05 PM   #1
bzrut
1974 CJ5
Hello, I have a cj5 that cant drive straight, steering kinda gets hard then releases then veers off in whatever direction it's pointing. it has new tires and are aligned. Tie Rod End all good, Im guessing a bad steering pump. Any advice thanks.
bzrut is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 09:45 PM   #2
John N
1981 CJ8
Bad u-joints in the front axle shafts.....just a guess.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 05:53 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You can loosen off the belt on the pump to see if the issue changes. I would be checking out the axle u-joints as mentioned too.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 11:14 AM   #4
Partsmke
1998 YJ Wrangler
The steering gear itself comes into question as well as the ball joints that support the knuckles. The ball joints can be bound up or the top adjuster too tight, also check to see if any part of the knuckle or steering linkage is contacting something else causing bind.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 03:06 PM   #5
chatham
check in the back for empty beer cans, it might be a clue
chatham is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 10:25 AM   #6
Partsmke
1998 YJ Wrangler
It amazes me that people post crap on a thread intended to be serious about a problem that many of us try to be thoughtful and lend our knowledge in an effort to be helpful.
Unread 05-20-2015, 11:29 AM   #7
Hawk4097
Hard to say on your description. Jack up the front and have someone turn the wheel both ways and check every connection for play. Binding could be coming from your steering gear.
Hawk4097 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 11:45 AM   #8
Scuter83
1974 CJ5
When I had that it was the joint at the bottom of the steering shaft. Mine would pop out of alignment and then break free. For me it would lock the steering until I could break it free!! Heavy duty shaft replaced it.
Scuter83 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 03:07 PM   #9
chatham
Whoooaaa lighten up, he is getting a lot of good information, I just thought his description of how it drove sounds like how I drive after a few beers. a good sense of humor helps fix a lot of things as well. notice the smile I added at the end.
Unread 05-20-2015, 05:25 PM   #10
Steve79cj7
Steve79cj7's Avatar
1979 CJ7
Check upper and lower ball joints, jack the front end up and see if you can move the tire. You should be able to track down whats moving
You said tie rod ends, what about drag link and sway bar bushings?
Front bearings can cause a problem too. Theres allot of parts up there. I just did mine and wound up replacing all the above and the
the ball joints and bearings made the biggest difference. The parts are not that expensive and if you wind up doing the u joints like John N said then you will have most of them off anyways. If you do ball joints just make sure you do them in the right order and torque everything to specs
My 84 CJ7 build, lots of photos in progress
http://www.jeepforum.com/forum/f8/ne...apart-2904938/
Steve79cj7 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 06:11 PM   #11
KauaiOffroad
Axle u-joints are definitely a prime suspect given that it binds and then releases. Steering shaft joints are a good place to look too and possibly the steering gear box once you've ruled out everything else.
In my experience a bad ps pump wont make the steering behave erratically like that. It just makes it harder to steer.
KauaiOffroad is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 07:28 PM   #12
80cj
80cj's Avatar
1980 CJ5
When I rebuilt my D30 I was surprised at how difficult it was to turn the steering knuckles until I pulled the axle shafts. The Jeep was 25 years old then and everything in the D30 was OEM.
80cj is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:07 PM   #13
bzrut
1974 CJ5
Hi guys, after reading all your responses I decided to just order all the parts you all mentioned. parts should be here by next week. I'm attaching a picture, paint job will be da last. Thanks again.
Unread Yesterday, 12:24 PM   #14
hbar
1979 CJ7
If mine looked like that, I would not be painting it. Purple jeep FTW! Not sure about the lantern hanging off the rocker though. YMMV.
hbar is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:32 PM   #15
80cj
80cj's Avatar
1980 CJ5
Wow! Extremely long shackles in the back. How long are the front ones? Vehicle attitude has an effect on caster angle too. Could be part of your steering problem.
