74 cj5 problem - JeepForum.com
post #1 of 9 Old 09-03-2013, 07:35 PM Thread Starter
Leeharvey92
1974 CJ5
74 cj5 problem
I just bought my second jeep. A 74 cj5. I'm having a problem with starting it once its warm. When it's cold it fires up just fine but if I've driven it and turn it off, it doesn't want to start for several hours. I think that it's vapor lock but I'm not sure. Any suggestions on what the problem is or how to fix it?
Leeharvey92 is offline
post #2 of 9 Old 09-03-2013, 08:01 PM
superj
Which carb do you have? What makes you think its vapor lock?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 9 Old 09-03-2013, 08:19 PM
CSP
Vapor lock shouldn't be an issue for several hours.
CSP is offline
post #4 of 9 Old 09-03-2013, 09:01 PM Thread Starter
Leeharvey92
1974 CJ5
Thought that it was vapor lock because venting the gas line and pouring enough cold water on it solves the problem
post #5 of 9 Old 09-03-2013, 10:11 PM
CSP
Is the tank vented to the charcoal canister which would have been below the master cylinder between the firewall and inner fender?
If not, and you don't have a vented cap that may be your problem. The gas that leaves the tank to make it run has to be replaced by air or it creates a vacuum. If it's strong enough, the pump just quits pumping fuel.
CSP is offline
post #6 of 9 Old 09-04-2013, 05:16 AM Thread Starter
Leeharvey92
1974 CJ5
It's vented, and I don't have the problem until I shut off the engine and then try to start it again. If it stays on it runs like a champ
post #7 of 9 Old 09-04-2013, 05:31 AM
colojeepguy
1970 CJ5
It may simply be a heat soak problem. Gas boils in the hot carb & floods the engine. When you try to start it hot, hold the gas pedal all the way to the floor, then crank & crank & crank. An insulated carb spacer can help this problem, also some brands of fuel seem to be more prone to boiling than others. Try switching gas stations.
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #8 of 9 Old 09-04-2013, 06:14 AM
bkeese
1949 CJ3A
If you think it's vapor lock, is the fuel line steel? If so, insulate the fuel line and move it away from the exhaust manifold (heat source) and as colo said a spacer under the carb.
Check the compression, hot and cold. Maybe a tired engine with no enough compression to start when hot.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #9 of 9 Old 09-05-2013, 05:10 PM Thread Starter
Leeharvey92
1974 CJ5
Thanks guys. Let you know if that works
cj5 , jeep , problem
