'74 CJ5 Fuel Sender Removal Help?? - JeepForum.com
post #1 of 7 Old 03-25-2009, 07:01 PM Thread Starter
Scuter83
1974 CJ5
So I dropped my gas tank tonight in hopes of simply hooking up a wire to the fuel sender so I can have a functioning gas guage. Unfortunately, when I got it down there was no stud for a wire. There appeared to be some rubber nub with a broken wire coming out of it. I am going to replace the sender unit, but can't seem to figure out how to remove the old one. It looks like there is a ring I can pry up, but I don't want to if that isn't right. I tried to twist the whole sender unit, but it won't budge. Please, can someone clue me in as to how to remove the old sender without breaking anything so I don't have to buy a new fuel tank as well??
Thanks,
Scott
Scuter83 is offline
post #2 of 7 Old 03-25-2009, 09:01 PM
CrazyHorse6
1979 CJ7
Hope this helps - Before you start, first clean the work surface of the tank so when you do pull the sending unit, no gunk falls inside!
I'm not sure about the CJ5's, but my 7 had an outer lock ring with three screws that needed to be loosened first. Once those screws were loose, you could then turn the sending unit counter clockwise (if I remember correctly) to unseat the sending unit from the outer lock ring. Install your new sending unit and new gasket (ensure the sock filter doesn't fall off the bottom of the sending unit when you place it inside the tank), lock the new sending unit into place underneath the outer ring, and then tighten down the 3 screws.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #3 of 7 Old 03-25-2009, 09:40 PM Thread Starter
Scuter83
1974 CJ5
I cleaned the tank tonight and I can't find any screws. I also only have one line coming out of the sending unit. I think I don't have a return line stock on my tank/sending unit, although the one listed on 4wd.com that I bought showed a port like yours. I just figured it was a generic picture for all years. Anybody else have a suggestion on how to get it out?
Thanks,
Scott
Scuter83 is offline
post #4 of 7 Old 03-26-2009, 07:34 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Take a good look on the top of the sending unit. It should have a stud or a small threaded hole to accept a mounting screw. This is where your sending unit wire should mount. As pictured above there may be a grounding wire as well.
To remove the unit you shouldn't need to loosen any screws. clean and lube the lock ring. You will have to rotate it to remove it from the tank. You can use a spanner wrench or tap on the tabs with a drift/extension and a hammer to get it to turn. Once the ring is off, gently wiggle the sending unit till it is loose and remove. You can test it once it is out by attaching the gauge wire and grounding the unit body. Turn your key on and gently raise and lower the float. You should see a cooresponding movement on your gauge needle.
jeepdaddy2000 is offline
post #5 of 7 Old 04-01-2009, 06:38 AM Thread Starter
Scuter83
1974 CJ5
So I few quick hits with a hammer and screwdriver and the lock ring popped out. I figured that is what was needed, but I decided to do it right this time and ask before grabbing a hammer.
Thanks,
Scott
Scuter83 is offline
post #6 of 7 Old 04-01-2009, 04:47 PM
jeepdaddy2000
1971 CJ5
Thanks,
Scott
Not a very practical attitude for a Jeep owner
post #7 of 7 Old 04-01-2009, 07:16 PM Thread Starter
Scuter83
1974 CJ5
So more fuel sending unit issues. I just tried to install what I ordered from 4wd.com, and it doesn't fit. I mean the lock ring will not fit over the 2 barbs on the top of the sending unit even though I ordered the kit from them. I try to put it on over the barbs, but the distance between the 2 is greater than the diameter of the lock ring!?! It also almost seems like the sending unit is too long, although it matches with what the part numbers say online. Anyone have any ideas? Looks like I will be calling customer service tomorrow.
Thanks,
Scott
Scuter83 is offline
Fuel Sender Help. Eagle2 Jeep CJ Forum 24 06-04-2009 08:42 PM
Need help ID-ing this Fuel sender BioTex Jeep CJ Forum 1 04-07-2009 06:41 PM
Aftermarket Fuel Sender kjhibbs Jeep CJ Forum 1 10-03-2008 01:38 PM
Chevy Fuel Sender in a CJ jfwireless Jeep CJ Forum 6 06-24-2008 07:36 AM
Will CJ Fuel Sender fit in YJ tank? 2000XPSD Jeep CJ Forum 3 04-17-2006 07:37 AM
