74/75 Decals on a 78 CJ5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 74/75 Decals on a 78 CJ5
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rock
Unread 02-04-2014, 07:10 AM   #1
bdatkins
1978 CJ5
I am planning to add Renegade decals to my 1978 CJ5. I replaced the tub a few years back and ended up with a tub with earlier model details (i.e. tailgate, little divot on rear quarter panel) and I changed the color from factory so I am no longer really worried about making it factory/year correct. I'm not trying to pass it off as an original renegade or anything like that. I just like the look. I specifically like the 72-73 decals and the 74-75 decals. I know that the length of the front end changed in what 72? And there were windshield changes in 75. Does anyone see any potential problems with putting the 72/73 or 74/75 decals on a 78? (logistical problems, not spiritual "staying true to the jeep" problems).
Here she is.
bdatkins is offline   Reply With Quote
Unread 02-04-2014, 07:35 AM   #2
bradleybrb
bradleybrb's Avatar
1975 CJ5
They should fit just fine. The only problem I can see is that if you use the center stripe down the hood. The cowl cover on the 72-75 is different from the cowl cover on the 76 and up, or at least from 78 and up for sure (not sure on 76 & 77). I couldn't tell from the pictures which cowl cover you have for sure. Having said all that, I still don't think that would be a big deal.
bradleybrb is offline   Reply With Quote
Unread 02-04-2014, 09:34 AM   #3
dg6772
Maybe you could have a graphics maker make your hood decal to fit your jeep or your needs. That's what I did for my eagle....
Dave in Muskegon using JeepForum
dg6772 is offline   Reply With Quote
Unread 02-04-2014, 11:42 AM   #4
LumpyGrits
IMHO-Looks great as is.
Sun's UV, and decals don't mix well.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 02-04-2014, 11:42 AM   #5
Pathkiller
1974 CJ5
They will fit just fine. The hood and fenders are the same from 72-86. Go for it. Just don't try to sell it later as something it's not.
74 CJ5 complete frame off restoration
82 CJ8 Scrambler Laredo. 4.6L stroker AX15 D300.
Pathkiller is offline   Reply With Quote
Unread 02-04-2014, 11:54 AM   #6
bdatkins
1978 CJ5
Yeah, I don't plan to sell her, but if I did I would be up front about everything. There are so many nearly spot on clones out there these days, it doesn't seem like the renegades are fetching that much more anyway.
Unread 02-04-2014, 11:55 AM   #7
bdatkins
1978 CJ5
LG
Thanks! I was wondering about that.
Unread 02-04-2014, 11:57 AM   #8
bdatkins
1978 CJ5
Was that a local print shop that did decals? How are they holding up?
Unread 02-04-2014, 12:58 PM   #9
dg6772
Yes it is. 2 Years and so far so good. I am in the north east and uv isn't as strong here as elsewhere,but they are good.
This it's a couple of days ago....
