73 CJ5 304cid water pump replaced - HELP! - JeepForum.com
post #1 of 3 Old 10-20-2003, 07:18 PM Thread Starter
qualityhardware
qualityhardware's Avatar
Just replaced the water pump on my '73 CJ5 with the AMC 304cid engine. The bearings holding the impeller shaft got chewed up and the thing was all misaligned, shaking and making a horrible noise while driving. As an added bonus, I spent an extra $3 on a new drive belt too.
Flushed the radiator and cranked her up. No leaks and the temp gauge was showing normal temp after I ran it for 20min and drove it around the block a couple of times.
Now a new noise is eminating from the pump area. Kind of a squeaking or weezing, but I'm really sure what it is. Could I have a fan belt too tight? Too loose?
I'm at a loss. This is a new noise that did not exist before, and again, I replaced the water pump and the fan belt and that's it.
qualityhardware is offline
post #2 of 3 Old 10-21-2003, 07:48 AM
fuzz401
1978 CJ7
could be the belt or the alt try a bar of soap on the belt and see if it stops making the noise if it does it has to do with the belt
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 10-21-2003, 12:38 PM Thread Starter
qualityhardware
OK. Will try. Thanks for the advice.
Just Replaced Water Pump and the temp gauge goes to max heat once driving semaJ Jeep CJ Forum 30 02-14-2010 11:32 PM
Misc. 79 CJ7 Brake, water pump and PS pump ques. 2Xtreme Jeep CJ Forum 9 12-03-2009 05:44 AM
Replaced water pump but it leaks now...blue RTV? connor014 Jeep CJ Forum 9 06-10-2009 09:06 PM
83 cj-7 w/304cid robnordmann Jeep CJ Forum 3 11-08-2006 12:16 AM
'73 304cid exhaust system question qualityhardware Jeep CJ Forum 4 10-17-2003 10:38 AM
