73 CJ drivetrain problem - JeepForum.com
post #1 of 4 Old 02-14-2002, 11:05 AM Thread Starter
gilb
Post 73 CJ drivetrain problem
I have a 258, 3spd, Dana 20 and I think Dana 44 rear end with 3:73 gears. Under throttle the vehicle pulls left and when you let up it pulls right, as in shifting (clutching). Under steady throttle vehicle runs straight. My rear driveline is not centered from transfer case to rear end. First when I measure where the driveline exits the D20 it is to the left(drivers) 3/4", measuring from the frame to the center point. On the rear end, the carrier is centered with the axle, but the shaft inputs 2" to the right (pass side). I am measuring from tire to center of where the shaft mounts. So overall the shaft is goes to the right 2 3/4", making a compound angle. Any ideas? would this no doubt be the pull problem?
gilb is offline
post #2 of 4 Old 02-14-2002, 11:40 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
Sounds like the rear diff has a locker in it to me!
Steve
OldJeepguy is offline
post #3 of 4 Old 02-14-2002, 12:01 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Could very well be locker-related, only one real way to find out . . . (acually, two, jack up the rear with the x-case in neutral and spin one wheel. If the other wheel goes the same way, Locker Ho!, if it goes opposite, open dif)
However, while I did not fully understand what you say, the angle of your driveshaft, and all of that other good stuff, should have nothing to do with your problem. Basically, everything remains constant, and the fact that you are under throttle, or steady, or coasting, can't be affected much but the angle of the drive shaft. I just figured out what you were saying, and I think that out of square suspension geometry may be the problem. Read on . . .
But, remember, that the force of the pinion turning tries to move the axle around a bit as it spins the ring gear (creep). This can cause squating under hard acceleration, and the forces are always present to some degree.
How are your rear springs and bushings? really tired stuff can, I think, show up in what you describe, but I didn't think it could be so severe. I have all new suspension on my CJ, and I can still feel some wander that is related to my right foot. It's the nature of the crappy steering and the short wheelbase (even shorter on your CJ-5). You may have just the usuall "exciting" highway ride.
But I'd make sure everything on the suspesion is in good order and torqued to spec. I'd even go for some poly bushings as well.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #4 of 4 Old 02-14-2002, 12:54 PM Thread Starter
gilb
Post
I jacked up the rear put the the transfer case in neutral and spinning one wheel does nothing to the other one. If I have it in gear and the transfer case engaged, when I spin one wheel the other goes the opposite.
Also I have put new shakel kits, inlcuding bushings all the way around and new shocks. Springs are the same but appear OK.
gilb is offline
Replaced clutch DRIVETRAIN PROBLEM fixinjeeps Jeep CJ Forum 2 08-23-2009 03:18 PM
I need drivetrain CSI DrNewland Jeep CJ Forum 3 08-14-2006 06:14 PM
CJ-7 Drivetrain Big_Black_YJ Jeep CJ Forum 16 01-04-2006 03:35 PM
drivetrain luck Jeep CJ Forum 2 03-11-2005 06:23 AM
Drivetrain Jeepdawg Jeep CJ Forum 3 11-25-2003 07:35 PM
