73-76 CJ5 Brakes Won't bleed - JeepForum.com
post #1 of 23 Old 09-21-2013, 11:19 PM Thread Starter
Greekcj5
1973 CJ5
Good evening ladies and gents. Here's my issue. I rebuilt my CJ5 and the last thing to do before taking it out is the brakes. Here's what I've done so far:
1: Tried bleeding them the conventional way (RR, RL, FR, FL)
2: Tried bleeding the front first (FR, FL, RR, RL)
3: Cleaned the proportioning valve
When trying method 1, I didn't have any fluid come out of the rear brakes.
When trying methos 2, I started seeing fluid come out then it disappeared and didn't return.
During method 3, I used air after cleaning the prop valve and each port worked as it should.
Also, when I press the brake pedal, there's about a 1-2 inch gap (play) before it's easy to tell that the master cylinder piston is actuating. It seems like a lot of play to me but I'm niether an expert nor a seasoned vet when it comes to this. I'm just a Nugget so I'm looking for whatever guidance is presented to me.
Having presented my findings, it seems to me the Master Cylinder is bad, however due to cost, I'd like to get the opinion of some pros before I make the decision to replace it.
If it's not and someone has another method of bleeding please let me know.
Greekcj5 is offline
post #2 of 23 Old 09-22-2013, 12:41 AM
dg6772
It may just have air in the m/c, have you tried bleeding the master?
Dave in Muskegon
dg6772 is offline
post #3 of 23 Old 09-22-2013, 07:21 AM
jp360cj
1977 CJ7
Dave in Muskegon
This^ If you didn't bench bleed the master cylinder before installing that is most likely the problem
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 23 Old 09-22-2013, 08:16 AM
hp_lovecraft
1981 CJ5
I've been able to do a quick "bench bleed" while still attached to the truck. I removed the lines, and jammed in a 6" piece of poly tubing into the hole, bench around back into the resoivoir, and pumped a couple times until no bubbles were in the tubing. I forgot the size of the tubing, but poly tubing is dirt cheap at the hardware store. Probobly 1/4"?
hp_lovecraft is offline
post #5 of 23 Old 09-22-2013, 09:29 AM Thread Starter
Greekcj5
1973 CJ5
Forgive me for saying this but I didn't know the master needs to be bled also. Obviously i have a lot to learn still. I'll try that today and update everyone later. Thanks
Greekcj5 is offline
post #6 of 23 Old 09-22-2013, 10:56 AM
OleBlue73
1973 CJ5
Bleed the MC on a bench to get full strokes with the pushrod. The pedal travel doesn't push it all the way to full get the air out when mounted on the jeep.
Also, when bleeding each wheel cylinder, the LR has the longest distance for fluid travel, so I'd bleed it first (assuming your setup of brake lines is stock).
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #7 of 23 Old 09-22-2013, 10:46 PM Thread Starter
Greekcj5
1973 CJ5
Gents, so here's the latest. I removed the MC and bench bled it. Re-installed it, bled the entire system and the brakes will stop the jeep now. However, I have to press the pedal all the way to the floor and only when I get to the very bottom, does it actually start stopping. It feels like the rod that's attached to the pedal is too short and if it were longer the pedal wouldn't have to travel as far to engage the brakes. What are your thoughts?
Greekcj5 is offline
post #8 of 23 Old 09-23-2013, 01:25 AM
dg6772
The rear brakes aren't working correctly. Thats where your pedal height comes from. Could be the adjustment is off or proportioning valve is messed up. The p/v can be reset.
Dave in Muskegon
dg6772 is offline
post #9 of 23 Old 09-23-2013, 09:30 AM
MoneypitCJ5
1977 CJ5
One thing I just want to throw out there......does your CJ use a combination proportioning/metering valve? If so, try bleeding the brakes by alternating front/rear as in, FR/RR/FL/RL. I just replaced the brake lines on my 77 and had to do it that way.
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #10 of 23 Old 09-23-2013, 10:25 AM Thread Starter
Greekcj5
1973 CJ5
Thanks moneypit. I'm not sure if there's a metering valve. I can tell the master is not the one for my year set up though. I'm almost flying blind cause the PO had a lot of units replaced and some haven't worked right so far which has led me to make adjustment during the entire rebuild. i drove it for the first time in two years last night and as long as i pressed the pedal all the way down it would stop on a dime.
Greekcj5 is offline
post #11 of 23 Old 09-23-2013, 10:36 AM
MoneypitCJ5
1977 CJ5
I'm almost to the same point with mine. I started working on it as a basketcase back in February and I'm hoping to get it on the road for the first time before it gets too cold!
Good luck!
post #12 of 23 Old 09-23-2013, 10:39 AM Thread Starter
Greekcj5
1973 CJ5
Thanks. You too.
Greekcj5 is offline
post #13 of 23 Old 09-23-2013, 01:43 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I don't know if your CJ has front disk brakes or not, but Ill throw this out there because it's a problem that others have run into. If it does have disks in the front, make sure the calipers are not on backward because this will allow air to be trapped in the system. The bleeder screws need to be the upper side, not the bottom.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #14 of 23 Old 09-23-2013, 01:49 PM Thread Starter
Greekcj5
1973 CJ5
i have 4 wheel drums.
Greekcj5 is offline
post #15 of 23 Old 09-23-2013, 01:58 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
When bench bleeding, how many times did you press the in the piston? If it was just a few, it could still have air in it. When I did my MC, I think I worked it over 100 times because I didn't want to have to pull it out and re-do it
Ken4444 is offline
brake master cylinder , brakes , cj5
