is a 73 258 6 cyl the same as an 82? - JeepForum.com
post #1 of 7 Old 11-26-2013, 05:33 PM Thread Starter
COBRA5LADDICT
other than being 1 bbl and not 2 bbl.
COBRA5LADDICT is offline
post #2 of 7 Old 11-26-2013, 05:53 PM
WindKnot
1977 CJ7
Substantially, yes. Exactly? No.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 7 Old 11-26-2013, 06:03 PM
hp_lovecraft
1981 CJ5
There was a major redesign in 1980, mainly to reduce weight. Lighter block, heads, manifolds, etc.
The engines look identical, but lots of little things don't fit. Typically, people don't even realize that they have a swapped engine until they buy some parts (ie valve cover gasket, water pump, etc), and they don't fit like the should.
hp_lovecraft is offline
post #4 of 7 Old 11-26-2013, 06:13 PM
atopi3
the head on the 73 has a week spot that cracks but by 80 that has been fixed
Alan Haney
atopi3 is offline
post #5 of 7 Old 11-26-2013, 09:47 PM
CSP
Head bolt sizes are different. For 81-84 they are 7/16" and all other years are 1/2".
CSP is offline
post #6 of 7 Old 11-27-2013, 11:44 AM Thread Starter
COBRA5LADDICT
could i use the intake and exhaust manifold from my 81+ on the earlier 258? also i am mainly concerned with mounting points for alternator, power steering pump air pump etc.
post #7 of 7 Old 11-27-2013, 01:30 PM
CSP
Yes you can. My '75 has the later intake/exhaust manifolds.
The '73 block may or may not have the mounting bosses for the power steering pump brackets.
CSP is offline
