727 in a CJ - JeepForum.com
post #1 of 8 Old 12-05-2007, 03:22 PM Thread Starter
jeepcj7304
727 in a CJ
I Bleew Up My Tf 999 For The Third Time So I Bought A 83 Wagoneer And Took The 727 Out Of It It Runs Fine But I Am Concerned About How Close The Front Driveshaft Is To The Bottom Of The Trans Pan I Am Running A 4 Inch Lift Plus A Small Shackle Lift Anyone Hane Issues With This Or Is It Not Going To Be A Problem When Flexing.
jeepcj7304 is offline
post #2 of 8 Old 12-05-2007, 03:48 PM
jason m
Nothing but the facts
jason m's Avatar
it will beve a very tight fit to clear the front drive shaft. my friend and i had to build a two piece drive shaft to clear the pan with the dana 300. great tranney's ( the 727 ) but the jeep model found in the waggy's are not made for pass side drop. this is why the triple 9 ( 999 ) works so much better. on the flip side the triple 9 we have in a rubicon has the same problem but on the drivers. the front shaft is a pieace of 1.5'' .188 wall and its about the only thing that could fit without hitting the pan when it gets dented/bent, jason.
jason m is offline
post #3 of 8 Old 12-05-2007, 07:09 PM
The Von
1981 CJ7
I have a 360-727-300 combo in my jeep. It was installed by the PO so I dont know what was involved. I know my front axle is moved 2" forward. Not much help I know but at least you know it can be done.
1981 CJ7
Specs to come.
The Von is offline
post #4 of 8 Old 12-06-2007, 08:43 AM
jpfaris
1979 CJ7
Having full width axles moves the driveshaft over to the PS, away from the pan.
79 CJ7, 304, TF727, D300, FULL WIDTH D44's, 4.56:1, SPOOL LOCKERS, SOA, OUTBOARDED, SHACKLES REVERSED, HOMEMADE D-SHAFTS, 38.5" BOGGERS
jpfaris is offline
post #5 of 8 Old 12-06-2007, 10:49 AM Thread Starter
jeepcj7304
i am full width and it is still under the pan
post #6 of 8 Old 12-06-2007, 07:36 PM
jpfaris
1979 CJ7
what t case and axles do you have? If dana 300, did you clock it? Have you lowered your tcase? Have you flexed it?
need more info
jpfaris is offline
post #7 of 8 Old 12-06-2007, 07:51 PM Thread Starter
jeepcj7304
i have factory axle set 30 front 20 rear. i have not flexed it and my transfer is not clocked. i was running a 1 inch transfer drop but removed it to gain a little extra clearence. plan to flex it soon just need the snow to go away for a few days.
post #8 of 8 Old 12-06-2007, 08:11 PM
flexncj7
If you have stock axles, you're not 'Full Width'. That term is used to describe using much wider truck axles in a Jeep.
I ran a 727 in my CJ with a 4" lift. I too was concernced about driveshaft clearance, and wound up notching the transmission pan. Worked great, but I couldn't clock the tcase the way I wanted to, and wound up swapping in a 999.
1985? Jeep CJ-7: 360, 999, D300, LOMAX 4:1, Dana 44s, 4.10's, Aussies front & Detroit rear. S0A, York OBA, YJ tub, 36" IROKs-
1989 YJ Sahara: 258, puko tranny, np231. 2-3" spring and 2" body lift. 33" TSLs- latest project.
flexncj7 is offline
