72 cj5 steering shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 72 cj5 steering shaft
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 03-03-2002, 03:25 PM   #1
jtd
Post 72 cj5 steering shaft
Can someone tell me if there should be downward play in the steering shaft of my 72 cj5?
I replaced the shaft, steering wheel and u joint coupling (not a project i would recommend). I have torqued down the steering wheel using all parts within the steering column: bearing, bushing for turn signal switch and the spring directly under the steering wheel. While sitting in the driver seat I can depress the wheel and shaft about 1/2" and it springs back up to the top when I let go. Everything is bolted up from the steering wheel to the Saginaw box. I can't find anywhere to take up further adjustment.
This project started with a replacement steering wheel and turned into a nightmare. Removal of the original wheel required drilling out the connection to the steering shaft, which ruined teeth. I found a used column assembly and put everything back together, but now the brass bushing which is supposed to contact the turn signal switch doesn't match the switch contactor location and I need to yank the new wheel to move the bushing. I can't seem to remove the steering wheel without ruining it - a one time install for this part.
Has anybody replaced steering column componets on 72 - 75 cj's? Any insight would be apprecitated.
jtd is offline   Reply With Quote Quick reply to this message
Unread 03-05-2002, 09:23 AM   #2
NC74CJ
Post
go to the auto parts store and ask for a steering wheel puller! im sure they can fill you in how to us it. Good Luck
Bill
A stroke bolder, a pinch better.
NC74CJ is offline   Reply With Quote Quick reply to this message
