`70 CJ5 transfer case shifter position? - JeepForum.com
post #1 of 4 Old 12-01-2011, 11:29 AM Thread Starter
ShaggieSAM
1983 CJ7
I am getting my `70 CJ5 back on the road (only drove it a few miles before the carb was all gunked up since it sat in a garage since `07). It was a recent purchase and I knew it needed a small amount of work to get it running well. The previous owner last drove it in 4WD. It does have a 3 speed manual and I know those gear positions, but I don't know the Transfer Case positions nor does it have a sticker or "grooves" to indicate the 4H, 4L, N, 2H, 2L position.
1.) What are the model numbers for my stock/original equipped transmission and transfer case?
2.) What are the transfer case shifter positions.
3.) No matter what position I had the transfer case in, it always "peeled wheels." The clutch was either all or nothing and never a smooth transition from stop to go. I do know I have 4.1 gears and 31" BFG MT. Is it the gearing, clutch, or a tremendous amount of power coming from the Dauntless V6 225? Or a combination of all?
4.) Considering #3 and the BFG MTs, will I lose traction when using it for commutes in snow?
Thanks for any help...........................Here is a link to some pics of my CJs x2.
ShaggieSAM is offline
post #2 of 4 Old 12-01-2011, 11:46 AM
CSP
Stock transmission should be the T14 and the transfer case would be the Dana 18.
Here's what the original sticker would have looked like:
It's available here: http://www.bearcreeksurvey.com/NOSRepro.htm
Sounds like you have clutch issues or possibly crap built up on the flywheel making the clutch chatter.
CSP is offline
post #3 of 4 Old 12-01-2011, 11:51 AM Thread Starter
ShaggieSAM
1983 CJ7
Great reply, thank you very much.
I am not losing my mind when I say that there aren't any "grooves" for the positions am I? Is this normal or a problem? Maybe I am just used to my`83 Dana 300 getting stuck and hard to get out of 4WD?
Is there a manufacturing company that produces this label? <-- Oops, nevermind, just check out the link.
post #4 of 4 Old 12-01-2011, 12:08 PM
CSP
With enough slop from wear and tear over the years it can be tough to distinguish one position from another.
CSP is offline
Transfer case shifting oddly...Gears in wrong position? cjthor Jeep CJ Forum 4 06-15-2010 05:02 PM
4wd shifter came out of transfer case rcawrse Jeep CJ Forum 3 12-30-2009 01:25 PM
Transfer case, the big shifter, the little shifter, and oddness senaTTor Jeep CJ Forum 10 10-17-2006 06:52 PM
Transfer case shifter bzzdagok Jeep CJ Forum 2 01-01-2004 04:24 PM
I need a transfer case shifter lever for my CJ jeepin cj-5 Jeep CJ Forum 15 09-20-2002 09:31 PM
