68 Cj'5 steering box removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 68 Cj'5 steering box removal
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-16-2011, 06:03 PM   #1
wyattrhicks
need a diagram to see how to remove and take out the steering box. thanks in advance.
/JeepBoy/
wyattrhicks is offline   Reply With Quote Quick reply to this message
Unread 11-16-2011, 06:37 PM   #2
wyattrhicks
? bump help please
/JeepBoy/
Unread 11-16-2011, 11:23 PM   #3
jeepdaddy2000
1971 CJ5
You can keep the wheel on, but you will have to remove the floor pan to access the top bolts. Otherwise, you can pop the wheel (no small feat) and either pull it and the pan from the top, or jack up the Jeep and drop the column and box from the bottom.
http://www.google.com/imgres?q=ross+...:4&tx=92&ty=30
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2011, 08:10 AM   #4
wyattrhicks
helpful^ thank you.
/JeepBoy/
