68 cj 5 wont start up - JeepForum.com
post #1 of 10 Old 03-09-2007, 09:52 PM Thread Starter
wavephinder
so last weekend i had my 5 up and running, i went away for work and came back this yesterday and it wouldnt turn over. would the fact that it was in the single digits temperature wise this week have something to do with it?
wavephinder is offline
post #2 of 10 Old 03-09-2007, 09:55 PM
c17load83
That weather could have easily killed the battery, did you check it?
c17load83 is offline
post #3 of 10 Old 03-09-2007, 09:55 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
More likely your alternator is not wired correctly and is draining your battery when the ignition is off.
Some diagrams from the great folks over at www.earlycj5.com:
http://www.earlycj5.com/tech/electrical/index.php
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #4 of 10 Old 03-09-2007, 09:57 PM Thread Starter
wavephinder
if my battery was dead my lights and radio wouldnt work right? because those work
post #5 of 10 Old 03-09-2007, 10:07 PM
jayhawkclint
1970 CJ5
Yup. An alternator would only take about an afternoon to kill your battery. Next move to the POS batt cable. Clean the posts, check the wire, the connection on the starter, etc. That link is a great site with some really knowledgeable people. You got a V6 or F-head?
post #6 of 10 Old 03-09-2007, 10:10 PM Thread Starter
wavephinder
v6, im a newbie to the cj and could use all the help i can get. thanks.
post #7 of 10 Old 03-09-2007, 10:48 PM
Trapshooter
When you turn the key, do you hear any clicking from the solenoid on the starter?
Trapshooter is offline
post #8 of 10 Old 03-10-2007, 07:13 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
V6's are notorious for starter failure due to the primary ignition(key) lead being too small. Try attaching a jumper lead from the solenoid stud and touch it to the pos batt terminal(be sure the rig is in N and the E brake is on). If it cranks, you might have to wire in a Ford style solenoid to eliminate the problem. I made this mod about fifteen years ago and have never had a problem since. Of course you need to check the battery first.
jeepdaddy2000 is offline
post #9 of 10 Old 03-10-2007, 01:20 PM Thread Starter
wavephinder
started right up this morning. i went for a long drive, ran fine. after i checked the connections and everything seemed fine. well my gauges dont work so i guess thats the next demon to tackle. thanks again. earlycj5.com...great site
post #10 of 10 Old 03-11-2007, 10:52 AM Thread Starter
wavephinder
so i went to go for a ride this morning and it doesnt turn over again. i went through the usual routine of trying to choke it and still nothing to the point where it just clicks...i assume thats the starter? any suggestions?
68 cj5
Wont start when it's hot outside Hank86 Jeep CJ Forum 4 08-07-2009 04:50 PM
83 CJ7 Wont Start Demo Jeep CJ Forum 4 06-27-2009 03:22 PM
key wont start the toy 72JEEPCJ5 Jeep CJ Forum 4 12-24-2005 12:09 PM
CJ7 wont start...what gives Quackerbox Jeep CJ Forum 8 09-03-2005 06:27 PM
cj wont start help! byrdman Jeep CJ Forum 0 06-03-2004 12:22 PM
