'67 cj5 will not crank - JeepForum.com
post #1 of 8 Old 02-28-2011, 08:14 PM Thread Starter
frank1986
I gave the jeep a tune up: changed spark plugs, wires, oil change cleaned the carb., drained all the old gas out, ect. It fired right up no problem idled fine sounded great. I took it down the road and it spit and sputtered so i stopped and it still just idled fine. when i went to take off it went dead and i have can not get it to start back up to save my life. can someone please help me with this? this is my first jeep rebuild and i want to get it running good before i get to the cosmetic parts.
frank1986 is offline
post #2 of 8 Old 03-01-2011, 08:28 AM
CSP
So when you say it won't crank, will the starter not turn the engine over or will it not fire once the starter does turn it over?
CSP is offline
post #3 of 8 Old 03-01-2011, 08:45 AM
robdoggydog1
1970 CJ5
if it cranks over but not starting, can you see if you are getting fuel to the carb? you could have pinched a line when you re-installed the tank, happened to me before, give us some more details.....
robdoggydog1 is offline
post #4 of 8 Old 03-06-2011, 05:28 PM Thread Starter
frank1986
I got it to finally crank and it ran fine for about 5 min then went dead now I cannot get it to start again. Same situation before. Checked all the gas lines nothing looks to be pinched.
post #5 of 8 Old 03-06-2011, 05:33 PM Thread Starter
frank1986
Also the it will not turn over unless it is jumped off got the battery it had in it charged.
post #6 of 8 Old 03-06-2011, 06:04 PM
mwhanson
1967 CJ5
Maybe check the fuel filter...any junk that may have been in the lines might have clogged the filter...pending how long it was sitting wouldn't matter if you drained the tank (helps), still gonna find some gunk somewhere.
mwhanson is offline
post #7 of 8 Old 03-06-2011, 06:44 PM
NewdRiver_
Alternator is bad.
NewdRiver_ is offline
post #8 of 8 Old 03-06-2011, 06:52 PM
robdoggydog1
1970 CJ5
only because i just had a similar problem, do you have a ballast resistor ? what volt reading do you get at the coil with ignition turned to "on" (not running) after you get this reading , start it if it will run for a minute and test how many volts you get at the battery, this will eliminate some of the ignition issues.
304 crank in a 360? I6CJ7 Jeep CJ Forum 3 06-14-2010 03:04 PM
CJ5 won't crank, Help! blackhawk51 Jeep CJ Forum 6 06-13-2010 01:26 PM
CJ7 will not crank! hummer6504x4 Jeep CJ Forum 2 04-03-2010 08:12 PM
4.0 crank in a 258???? 78treehugger Jeep CJ Forum 20 11-25-2009 02:56 PM
Won't Crank crrushing Jeep CJ Forum 2 02-16-2008 01:14 AM
