66cj rochester carb kits? - JeepForum.com
post #1 of 8 Old 01-08-2010, 09:31 PM Thread Starter
barlow
1966 CJ5
hey all', My 66cj has a Rochester single BBL and there appears to be a leak on the driver side? I have not determined where exactly the problem is, but there is a bit of gas on the manifold. I could not get my rig running tonight and it smelled like gas!!! Any thoughts on how to locate a rebuild kit and/or a diagraham of the carb? Thanks so much!
barlow is offline
post #2 of 8 Old 01-08-2010, 09:38 PM
72jtruck
1972 FSJ Gladiator
best bet is to find a chevrolet that had that carb and start looking for parts for that vehicle. Guys at all the parts stores told me they couldnt get a carb kit for my 2 barrel on my cj then i went in and asked for a carb kit for a 67 C10 with a 283 2 barrel and they had it in stock. it wouldnt show a part number for my jeep anywhere i went. Just have to research and find a one barrel chevy of about the same year, then go to the parts store with the info for that vehicle.
1969 CJ5 1972 J2000 thriftside
1979 J10 1993 ZJ Limited
72jtruck is offline
post #3 of 8 Old 01-08-2010, 11:09 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Your V6 has a 2bbl 2GC. Easy to find at any FLAPS. Check the other post for more info.
jeepdaddy2000 is offline
post #4 of 8 Old 01-09-2010, 09:32 PM
72jtruck
1972 FSJ Gladiator
Did all cj v6 have a 2bbl? i had a 70 commando with a 1bbl carb. didnt know if they ever used it in the cj
72jtruck is offline
post #5 of 8 Old 01-11-2010, 05:49 AM
jeepdaddy2000
1971 CJ5
I have worked on a ton of 225's over the years and have never seen a factory setup with anything but the small 2GC(not saying that something weird isn't possible). This is also the carb called for in all the manuals that I own. Perhaps it is a 198 or somebody has switched a different manifold on.
If it is a one barrel, it should be a Monojet. THese should be easy to find as well. I would check Chevy six cylinder p'up or auto applications for the same year.
post #6 of 8 Old 01-11-2010, 08:30 AM Thread Starter
barlow
1966 CJ5
My cj has a single BBL and I was able to remove it last night to find some numbers. I hope napa will be able to locate a rebuild kit. Please let me know if there is another retailer to try for ordering the kit? Thanks.
barlow is offline
post #7 of 8 Old 01-11-2010, 08:44 AM
Nickmil
Napa is your best bet for a local parts house. Their kits are better quality and actually come with the right parts vs. many of the other parts houses. I'd suggest a brass float at the same time. There are carb specialty shops that can be helpful as well but don't have the contact info handy. "The Carb Shop" is one that comes to mind.
'59 CJ-5, '59 CJ-6, '68 CJ-5, Bone stock '57 CJ-5, a couple of XJ Cherokees
Nickmil is offline
post #8 of 8 Old 01-11-2010, 08:56 AM
Mike Romain
The Haynes CJ manual has nice carb breakdown and rebuild drawings/photos in it.
Mike
Mike Romain is offline
Rochester 2gv martyweir Jeep CJ Forum 9 01-27-2009 12:58 PM
Rochester 1BB carb any good? SmichaelR22 Jeep CJ Forum 1 05-07-2007 10:22 AM
rochester 2se aksourdough Jeep CJ Forum 1 02-23-2007 11:33 PM
Motorcraft, Rochester, or Weber...carb advice for 258 twmattox Jeep CJ Forum 15 05-20-2005 01:49 PM
Rochester carb Hammer71 Jeep CJ Forum 2 12-28-2002 09:56 AM
