Quantcast 64 Cj 6 Questions!!! Please Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 64 Cj 6 Questions!!! Please Help
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 09-27-2005, 11:36 PM   #1
jeep jake
I'm looking at a 64 cj6 it is bone stock for the most part it has the stock 76 horse 4 cylinder, 3 sp. The owner said that it tops out at 45, when it was running great. It puffs out white smoke, I think the valves are ruined because it was never changed to run unleaded fuel and that is what this guy has been running. If the engine was rebuilt and I swaped a t-18 trans or maybe a 5 speed. would I be able to go 65 ish. I just don't like the idea that I wouldn't be able to go on the highway if I needed to. Unfortinitly I don't have the cash to do a engine swap and such. Please help if you could and let me know how much money a trans and rebuild kit costs ruffly.
Thanks alot, hopefully I'll have a jeep soon that not every other person has. referring to my TJ)
04 TJ 4.0 5-sp
35 bfg's
long arms
60's atlas ll
jeep jake is offline   Reply With Quote
Old 09-28-2005, 02:44 AM   #2
80cj
80cj's Avatar
1980 CJ5
I had a 64 CJ-6 exactly as you describe. When I blew a head gasket on it, it puffed white smoke. The best thing I ever did to that CJ-6 was a Chevy V-8 conversion along with a Warn overdrive. I ran a 283 V8 with a small four barrel and headers. Running 12-15 gumbo mudders with the 5.38 gears, a rear Power Lok and the overdrive gave me decent gas mileage and great performance. Never broke anything either. Why the hell did I sell it? That's what I keep asking myself.
80cj is offline   Reply With Quote
Old 09-28-2005, 06:06 AM   #3
CJ51973
CJ51973's Avatar
If you want to go faster ditch the stock motor. Even with an overdrive you won't make much more than 55. If you regear with that motor then it won't pull itself at all. That four is a great torque maker but won't crank RPM or horsepower. Like jeep jake said, engine conversion (a V6 might be enough) and an overdrive.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline   Reply With Quote
Old 09-28-2005, 08:41 AM   #4
earlycj5
Probably $1k to rebuild the F-head and another $300 for the T90 and some change for the D18. Just a WAG from helping friends rebuild their stuff.
OD would probably be enough with a strong F-head to get you up to 60 or 65 on the flat stretches. I've had a 3B with an F-head up to 55 w/ no OD (for very short periods of time).
regards,
Sparky
earlycj5 is offline   Reply With Quote
Old 09-28-2005, 03:40 PM   #5
jeep jake
thanks for all the help i'll have to think more about it.
04 TJ 4.0 5-sp
35 bfg's
long arms
60's atlas ll
Old 09-28-2005, 04:01 PM   #6
jeep jake
the guy told me it runs on a 6 volt system is there any way to change it to a 12 volt system
04 TJ 4.0 5-sp
35 bfg's
long arms
60's atlas ll
Old 09-28-2005, 04:05 PM   #7
jeep jake
rite now it has a generator rather then a alternator
04 TJ 4.0 5-sp
35 bfg's
long arms
60's atlas ll
Old 09-28-2005, 06:57 PM   #8
earlycj5
Unless someone went to alot of effort the 6 volt system was easily gone by '64, phased out in the '50s in favor of 12V.
Generators are not uncommon. A single wire Delco internally regulated will work nicely. We just discussed it in my forum the other day. Stop by and do a search.
http://www.earlycj5.com/forums/
regards,
Sparky
Glock Forum
