61 Willys Master Brake Cylinder - JeepForum.com
post #1 of 4 Old 03-11-2008, 04:06 PM Thread Starter
lynndiwagon
1961 CJ6
Hello all, I have an original 61 Willys CJ that I use for running around the lake in. Brakes just went out. The master cylinder appears to be original...as all other parts. Went to remove it discovered that the rear bolt holding it on won't clear the part due to hitting on the engine. It's a bear to get to anyway and there is a plate under it. I need to get the rear bolt out so I can get the plate off and get to the single brake line. Any hints? Thanks for any help, I'm a new member and look forward to any help.
Lynn Wagoner
Yukon, OK
lynndiwagon is offline
post #2 of 4 Old 03-11-2008, 06:28 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
I had to lift my tub a little to get my master out. Try here, best site on the 'net for '55-'71 info:
www.earlycj5.com
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 4 Old 03-13-2008, 06:52 AM Thread Starter
lynndiwagon
1961 CJ6
Thank you sir.....I'll check it out.
post #4 of 4 Old 03-13-2008, 07:20 AM Thread Starter
lynndiwagon
1961 CJ6
Follow up
Jayhawkclint, thanks again for the link to the old jeep board. Very nice, and it looks like I will find all of the info I need. Hope to see you over there.
Lynn Wagoner
Yukon, OK
Brake master cylinder question. moonpie312 Jeep CJ Forum 2 08-04-2009 03:51 AM
Brake Master Cylinder 78treehugger Jeep CJ Forum 1 05-07-2009 11:20 AM
master cylinder/brake booster chiliman77 Jeep CJ Forum 3 02-10-2008 01:17 AM
Brake Master Cylinder jp360cj Jeep CJ Forum 4 01-24-2008 05:56 PM
CJ8 Brake Master Cylinder? mferrari Jeep CJ Forum 8 03-21-2007 09:58 PM
