6.0 Vortec Swap questions - JeepForum.com
post #1 of 6 Old 02-06-2009, 11:21 AM Thread Starter
Hardy350
1978 CJ7
I have some questions for my 6.0 vortec swap in my CJ-7
It is a fuel return line required ?
Fits the oem exhaust manifolts the engine bay or need i shorty headers?
What for brand of Tachometer it is required or fits the oem Jeep Tachometer?
Sorry for my not so perfekt englisch...
Greetings
Hardy
Hardy350 is offline
post #2 of 6 Old 04-06-2009, 08:14 AM
green cj 78
1978 CJ7
Fuel Return line depends on the year, check ls1tech.com for that info.
I used Hooker Block Hugger headers, and will have to have the pass side modified to fit. I had problems with the drivers side fitting, You may have to see how they fit when you put the engine in.
78 CJ7
5.3 Vortec, T18, Dana 20, AMC 20, Dana 30
97 XJ 2wd POS.
green cj 78 is offline
post #3 of 6 Old 04-06-2009, 08:46 AM
kickingprop
my 5.3 vortec swap required a return fuel line. I was unable to use the 5.3 exhaust manifolds and opted instead for some shorty headers as well.
I'm not sure on the tach but I dont imagine the oem tach will work. I believe Autometer makes a tach that is computer controlled that will work with the Vortec motor's CPU
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #4 of 6 Old 04-06-2009, 08:58 AM
green cj 78
1978 CJ7
Just use autometer electric gauges. Easy...
78 CJ7
97 XJ 2wd POS.
post #5 of 6 Old 04-06-2009, 11:56 AM Thread Starter
Hardy350
1978 CJ7
Hardy350 is offline
post #6 of 6 Old 01-24-2011, 07:04 PM
hurley14
I Need Some HELP on my 1994 YJ that im doing a swap to a 2004 chevy vortec 6.0 with a 4l80E tranny 2wd i want to know witch way would be better to go.... Should i keep the 6.0 fuel injected or switch it to carb? so i can get a 4x4 tranny and transfer case to work something like a 700r? i want the transmission to stay automatic.. Or is there a way to keep the 2wd tranny switch it to 4x4 and get a transfer case to match up and will it be a manuel transfer case or a push button one? if it is a push button one will i need any new wire because my truck did not have 4x4 ???
If someone could please help me that would be great
Thanks
Troy call or text anytime 813-323-2531
hurley14 is offline
Engine Swap 99 5.7 Vortec Into Cj8 Rasshopper Jeep CJ Forum 33 02-10-2010 11:45 PM
4.3L Vortec a good CJ7 engine swap? DirtEater Jeep CJ Forum 5 11-05-2007 07:20 AM
4.3 Vortec ragincajunATL Jeep CJ Forum 4 10-10-2006 09:00 AM
Vortec 4.2L I6? Strelnikov Jeep CJ Forum 0 02-13-2003 04:14 AM
4.3 vortec swap MB83CJ7 Jeep CJ Forum 1 03-12-2002 10:17 AM
