51' CJ-3A Build... - Page 4 - JeepForum.com
post #46 of 64 Old 02-17-2013, 06:48 PM
brownbagg
1930 MK Compass
that 51 that you like so much has a 45- early 46 tub on it
brownbagg is offline
post #47 of 64 Old 02-17-2013, 06:50 PM Thread Starter
Viper723
more pics of the state of things right now...
Built not Bought.
"The walls between art and engineering exist only in our minds"-Theo Jansen
Viper723 is offline
post #48 of 64 Old 02-17-2013, 07:44 PM Thread Starter
Viper723
That is just the general look I am after... I think my tires may be a little bigger though...
Built not Bought.
Viper723 is offline
post #49 of 64 Old 02-24-2013, 11:34 PM Thread Starter
Viper723
I pulled the body off of the frame this weekend, and now that its off I can get a better sense of how things are going to fit. I am pleasantly surprised to see that the frame is in good shape under the mud and suface rust. I need to start making a plan of attack on everything that needs to be done now...
Built not Bought.
Viper723 is offline
post #50 of 64 Old 02-25-2013, 09:33 AM
row684
Nice! Wish I had the same luck with my last build!
row684 is offline
post #51 of 64 Old 02-26-2013, 07:34 PM Thread Starter
Viper723
I had stripped the windshield a while back and it started to surface rust, so I wire brushed it again and painted it. I am going to run a lexan windshield I think for shatter resistance and of course... Weight Reduction! Getting a piece long enough might be tricky though.
Built not Bought.
Viper723 is offline
post #52 of 64 Old 02-26-2013, 08:23 PM Thread Starter
Viper723
I am partially trading the engine for this new toolbox, so i got it painted up already since it was small enough to bring to school... I love the Jeep script embossing.
Built not Bought.
Viper723 is offline
post #53 of 64 Old 02-27-2013, 03:53 PM
row684
Nice! I wish the newer CJ's still had those boxes.
row684 is offline
post #54 of 64 Old 02-27-2013, 10:49 PM Thread Starter
Viper723
I might have a buyer for the drivetrain and the tires here, so that will go a good way towards funding my parts budget... and it will get rid of unnecessary parts around the yard.
Built not Bought.
Viper723 is offline
post #55 of 64 Old 03-01-2013, 08:20 PM Thread Starter
Viper723
I got the drivetrain out today! All of the driveshaft joints are in pretty good shape, and the mounts came off easy enough, I got the wheels and tires off as well, here are some pics of the process. Having an engine hoist has been invaluable. I think these parts will be useful for whoever snags em... They are greasy, but in decent shape.
Built not Bought.
Viper723 is offline
post #56 of 64 Old 03-03-2013, 01:30 PM Thread Starter
Viper723
I sold the drivetrain today along with the radiator, so hopefully next week I can start to find some axles...
Built not Bought.
Viper723 is offline
post #57 of 64 Old 03-08-2013, 07:53 PM Thread Starter
Viper723
I bought a Dana 44 off of a Ford Bronco. It is the cast wedges type ( i know i know) but the price was right. I will be able to work around them. Keeping with my cheap and cheerful theory on this build, I got what was the cheapest that would work. The rear axle is next on the list. I got the axles off of the frame already and I plan to start by stripping the back half of the frame and starting with the rear suspension. I am on spring break right now so I hope to get some stuff done.
Built not Bought.
Viper723 is offline
post #58 of 64 Old 03-14-2013, 08:34 PM Thread Starter
Viper723
So it is down to the bare frame now, and I am starting to get a sense of where everything will be placed. I started cutting the shackle hangers off ( welded and riveted on ) and I bedlined the parts of the frame that I already stripped the paint and rust on. It isn't restoration quality finish but it is tough and looks pretty dang good to me. I am going tomorrow to pick up the Ford 9 inch I am having my local junkyard pull off for me. I will need to regear both of course, but 125 bucks for a 9 inch seems like a good deal to me.
Built not Bought.
Viper723 is offline
post #59 of 64 Old 03-24-2013, 10:15 PM Thread Starter
Viper723
I got quite a bit done today. I put two of the 37's on the Ford 9 inch that is mostly cleaned now, and I mocked up roughly where it is going to sit (ignore the fact that it's backwards). It is going to have some nasty clearance, and I knew it would be that wide but it just looks like a monster haha. I cut the tow package a bit to make room for the rear spring mounts. I fabbed up the forward brackets from the original ones. I was pleasantly surprised to find that the original brackets had the same size bolt hole to go into the leaf spring bushing so it worked out great. I cut the spring perches off of the 9 inch (PITA) and I will have to fill weld some of the excessive grinding I did... I feel better now that I know where the rear axle is going to sit. That allows me to start figuring out everything else... One piece at a time.
Built not Bought.
Viper723 is offline
post #60 of 64 Old 07-06-2013, 11:04 PM Thread Starter
Viper723
I have the Jeep siting on its own springs now, and I have mounted the YJ steering box. I am beginning to figure out the engine mounts. I put the grill on it to see how big its going to end up being.... the answer is very
Built not Bought.
Viper723 is offline
CJ6 build - here I go again molsenice Jeep CJ Forum 395 11-06-2012 08:15 PM
Sold CJ7 time for CJ5 Build? Pros/Cons/Build Suggestions connor014 Jeep CJ Forum 0 08-25-2011 10:35 AM
Anyone ever build imafishingfred Jeep CJ Forum 1 09-30-2007 03:10 PM
**DEBATE** Build up cj2a or buy and build up cj5 Kevin Swayze Jeep CJ Forum 4 02-06-2002 02:07 PM
