51' CJ-3A Build... - Page 3 - JeepForum.com
post #31 of 64 Old 02-13-2013, 04:56 PM Thread Starter
Viper723
Now that the 4.0 swap is finally done, I can start to focus on the CJ! haha It should be a wicked fun project...
Built not Bought.
"The walls between art and engineering exist only in our minds"-Theo Jansen
Viper723 is offline
post #32 of 64 Old 02-13-2013, 09:34 PM Thread Starter
Viper723
The horsepower figure on the 95 2.5L engine is 120, and I can't imagine I have lost many seeing as it only had about 58k on it when I pulled it out. The CJ-3A only weighs about 2100 pounds, so that is nearly 120 HP per ton, which is pretty respectable considering its a WILLYS. The idea of having a V8 in it seems a bit much for the application I want it for, and I can't believe I didn't think of having the YJ drivetrain in it before.
My plans for this project are as follows:
  • Start with a very old and tired CJ-3 (not worth restoring for me judging by body damage and budget)
  • Drop in my 2.5L MPI YJ engine/ AX/5/NP231 drivetrain (should be cake )
  • add power steering, power brakes, and certain modern conveniences.
  • Pull a set of axles from a truck like my 76 Ford from a junkyard (Dana 50 front/9 inch rear)
  • Take the 37 inch muds from my 76 ford and slap em on (put the 33's back on the truck for usefulness)
  • do a SOA lift to clear the suckers.
  • Trim the rear wheel well to fit the tires (NO COMP CUT!!!) I want to keep some semblence of the Jeep look
  • I want to clean the frame up a bit and paint it, along with the body, which needs floors no matter how i slice it... once it works i will figure things out like a cage
All of this to be done for as little as possible on weekends mostly when I come back from school. Having the 4.0 swap under my belt gives me some confidence to take this on now haha
thoughts?
Built not Bought.
Viper723 is offline
post #33 of 64 Old 02-14-2013, 08:20 AM
row684
[*]Start with a very old and tired CJ-3 (not worth restoring for me judging by body damage and budget)[*]Drop in my 2.5L MPI YJ engine/ AX/5/NP231 drivetrain (should be cake ) [*]add power steering, power brakes, and certain modern conveniences.[*]Pull a set of axles from a truck like my 76 Ford from a junkyard (Dana 50 front/9 inch rear)[*]Take the 37 inch muds from my 76 ford and slap em on (put the 33's back on the truck for usefulness)[*]do a SOA lift to clear the suckers.[*]Trim the rear wheel well to fit the tires (NO COMP CUT!!!) I want to keep some semblence of the Jeep look[*]I want to clean the frame up a bit and paint it, along with the body, which needs floors no matter how i slice it... once it works i will figure things out like a cage
thoughts?
You had me until you said full size axles... If you have to outboard a 7 which is like idk a foot wider your going to have to hack them in a 3. 37's will probably make you taller than you are wide to.
IMO 4 banger stock axles and 33's would be a lot more fun.
row684 is offline
post #34 of 64 Old 02-14-2013, 11:13 AM Thread Starter
Viper723
I am getting rid of the stock axles for two reasons, and its not without thought... First off, the drop is on the wrong side for the front axle, so thats the problem there. I planned on keeping the rear initially, but as you said any front axle I get is going to be much wider than the stockers, and even 33's might have clearance issues at full stuff with that narrow an axle. As we know the spline count on the originals is not fantastic, among other things, but I think they would have held up to 33's for my style of wheeling. The reason for the 37's is simple... I have them, and I kind of want them off of my F150. Realistically a truck is more useful on the 33's I took off of it. It does sort of pain me to get rid of the original axles, but as I said before, I would like this build to be entirely reliable and useful for many applications, including street driving, so with the extra 10 inches or so of width it should be much safer.
Now as far as it being taller than it is wide, that is really a concern of mine, since I hate the way Jeeps look when they are lifted to the sky for no purpose, but I am going to try to keep that look to a minimum with the stretch I want to do so it won't look so un-proportional. The other issue I have when I see willys builds is the cage (who agrees?). I hate how tall they make it look, I'm not sure if those guys are really tall or what, but I am not, so I want to drop the seat position a hair and make a lower cage, still with safe head clearance however...
Built not Bought.
Viper723 is offline
post #35 of 64 Old 02-14-2013, 11:40 AM Thread Starter
Viper723
This is sort of the look I am going for, this one is even a 1951 haha
Built not Bought.
Viper723 is offline
post #36 of 64 Old 02-15-2013, 12:19 AM
row684
That's not bad, not my style, but it looks well done.
Have you looked into mounting the wider axles? Can they be done with severely out-boarding the springs? I'll post a pic of my father inlaws 52 M38 on 33's tomorrow we just finished resto-modding it last summer. Well 95% finished.
row684 is offline
post #37 of 64 Old 02-15-2013, 12:41 AM Thread Starter
Viper723
I would like that. The other reason I kinda want to go bigger on it is that I want something to play hard with, seeing as my YJ is my only reliable vehicle, and I can't afford to break that haha I don't really see why outboarding the springs would be necessary? Please explain your thoughts on that...
Built not Bought.
Viper723 is offline
post #38 of 64 Old 02-15-2013, 06:24 AM
hotrod351
1955 M-38
looks like youll have something to do for a while.
hotrod351 is offline
post #39 of 64 Old 02-15-2013, 09:57 AM
row684
The out boarding on the Cj5 and 7 is because CJ's have narrow frames so the springs aren't wide enough apart. the passengers side spring perch would have to be part way up the pumpkin to keep the axle centered under the vehicle. I believe the Willys frames were even narrower (but I could be wrong, it did happen once before )
row684 is offline
post #40 of 64 Old 02-15-2013, 02:13 PM Thread Starter
Viper723
Well that just makes sense... haha See its thi9ngs like that that you don't think of that will bite you, but I suppose I will have to figure something out when the time comes for that... I do know that it indeed has a pretty narrow frame
Built not Bought.
Viper723 is offline
post #41 of 64 Old 02-16-2013, 07:53 PM
row684
I pulled my 7 up nose to nose with the Willys and the Willys looked about a 1/4 to 1/2 inches narrower so you would have to outboard the axles. I hear its not to difficult if you can weld though.
My father in-laws 52 M38.
row684 is offline
post #42 of 64 Old 02-16-2013, 08:13 PM Thread Starter
Viper723
Wow that is gorgeous, if it was in better shape that is most likely how I would build it. One of my buddies has a similar looking CJ-3 but it is restored to stock. I will have to do a ton of welding on it anyways so its just one more thing to add to the list haha
Built not Bought.
Viper723 is offline
post #43 of 64 Old 02-17-2013, 12:12 PM
row684
Yeah he spent a ton of money on it and then drove it around the block once lol
row684 is offline
post #44 of 64 Old 02-17-2013, 02:32 PM Thread Starter
Viper723
I got the fenders cut off (somebody welded them on) and they are pretty much done for.... the seats also got cut out and I was able to get a full idea of the body damage. Its mostly the floor pans and braces that are toast, so I will have to put pans in and patch it all up best as I can. I have to downsize the pictures of the damage to post them.
Built not Bought.
Viper723 is offline
post #45 of 64 Old 02-17-2013, 06:33 PM Thread Starter
Viper723
Here is the drivers side fender where the brace is destroyed... I assume this was why it was welded on.
Built not Bought.
Viper723 is offline
CJ6 build - here I go again molsenice Jeep CJ Forum 395 11-06-2012 08:15 PM
Sold CJ7 time for CJ5 Build? Pros/Cons/Build Suggestions connor014 Jeep CJ Forum 0 08-25-2011 10:35 AM
Anyone ever build imafishingfred Jeep CJ Forum 1 09-30-2007 03:10 PM
**DEBATE** Build up cj2a or buy and build up cj5 Kevin Swayze Jeep CJ Forum 4 02-06-2002 02:07 PM
