5 speed in a CJ? - Page 3 - JeepForum.com
post #31 of 55 Old 01-14-2010, 11:40 AM
SuperSportCJ
1982 CJ7
I have a T5 on my 304 v8 for the time being and it has actually held up great even with the additional torque of the V8. I dont do any real hard offroading or anything but its definitely nice to have the 5th gear when cruizing above 50 or so.
SuperSportCJ is offline
post #32 of 55 Old 01-14-2010, 12:22 PM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I swapped in a NV3550 from a TJ... it wasn't cheap, but with 4.56's and a set of 35's on it... it was really a nice combination.
There are kits out there that gives you most everything you need. We had to source an AX-15 bellhousing inspection plate for the new TJ bellhousing, but all in all, it shifts nice and is really smooth with the hydraulic clutch... yup, I said it, do that as well and you won't have to worry about any issues with the mechanical linkage... update the clutch as well... by the time you are all said and done, you will be out a few g's...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #33 of 55 Old 01-14-2010, 12:23 PM
certifiablejeep
Bicentennial Nickel
1976 CJ5
You will need new driveshafts as well... and then you might even need larger wedges to turn your pinion up more depending on lift... yup, lots of things that go into this besides just the tranny...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #34 of 55 Old 01-14-2010, 12:26 PM
certifiablejeep
Bicentennial Nickel
1976 CJ5
Parts
http://www.certifiablejeep.com/image...e/100_0215.jpg
and the install...
http://www.certifiablejeep.com/image...e/100_0287.jpg
http://www.certifiablejeep.com/image...e/100_0304.jpg
all cleaned up... you can see that it is longer as well...
http://www.certifiablejeep.com/image...e/100_0507.jpg
If you get teh TJ bellhousing, you need the one on the left...
http://www.certifiablejeep.com/image...e/100_0590.jpg
all installed with the new driveshaft.
http://www.certifiablejeep.com/image...e/100_0602.jpg
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #35 of 55 Old 01-14-2010, 03:29 PM
mtbtweety
mtbtweety's Avatar
1982 CJ8
so silly question, but what's the difference between the Mustang T5s, and the Jeep T5s? Dimensions? Input / output shaft characteristics?
mtbtweety is offline
post #36 of 55 Old 01-14-2010, 03:38 PM
trailhead2004
1980 CJ7
Mainly tailshaft housing. The Jeep and International ones have a short tailshaft housing, I would really call it an adaptor.
I'm not sure if the Mustang T5's were the World Class variant or not, but there are differences between the WC and the Std T5's. The way I understand it, it has more to do with bearing type and syncro material than actual design.
HTH!
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #37 of 55 Old 01-14-2010, 05:53 PM
otterred
1976 CJ5
so is it just the jeeps t5 being blown up because i've driven a couple of non jeeps. v8 boss 302 (homebrewed) with t5 in early mustang and a 302 bronco and the t5s handle like a champs. They were world class mustang trans. But they were abused
otterred is offline
post #38 of 55 Old 01-14-2010, 06:54 PM
ragner
1983 CJ7
transmissions
sounds like apples vrs oranges the t4 and t5 are probably good if you just wanna get there, the ax15 will do a great job of gettin ya on the other side.
ragner is offline
post #39 of 55 Old 01-15-2010, 09:25 AM
Happy Joe
302 mustangs (post '83) typically had a WC T-5 (good for around 310 pound feet of torque if I recall correctly, the Jeep T-5 was designed for around 265 as I recall (if its important, please look up the spec.). The WC T-5 had some improved bearings and oiling. The WC was also used in some Chevy pickups and other vehicles (I don't remember if the splines were the same or different) but they typically came with a higher 3.76 first gear. The mustang T-5 also had a very high first gear and is really not applicable to jeeps because of that (and the long tail shaft).
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #40 of 55 Old 01-16-2010, 08:03 PM
hp_lovecraft
1981 CJ5
I was planning on replacing my SR4 with a T5, as it looks like an easy swap.
What is the best way to determine if I have a 10-spline or 14-spline trans? The VIN on my 1981 says it came with a 4-cyl, but the PO swapped in a 6-cyl. I assume the SR4 is still original, but who knows?
hp_lovecraft is offline
post #41 of 55 Old 01-16-2010, 08:50 PM
LJameson
If you really want to do something different, I'm sure it wouldn't be too hard to get the NSG370 (TJ 6 speed) in there.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #42 of 55 Old 01-18-2010, 01:18 AM
pazur
1981 CJ7
Ford and Jeep= 10 spline
GM maybe rest is 14 spline
Mustang T5 for 4 cylinders has also thinner input shaft
pazur is offline
post #43 of 55 Old 01-18-2010, 07:23 AM
cincyjeeprs
I would not assume that.
cincyjeeprs is offline
post #44 of 55 Old 01-18-2010, 11:51 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
And the gear ratios.
Jeep used the 14-spline behind the 4-cylinders, also.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #45 of 55 Old 01-18-2010, 12:11 PM
rustymudder
1982 CJ7
something I just want to put out there to consider is the overall gearing range of a transmission. a T-5's range is about 4.9 and my t18's range is 6.32 and I'm sure no one will debate that the T18 is much stronger than the other trannys mentioned(except maybe the NV4500).
Of course the T18 has large gaps between the gears and long, slow shifter throws.
rustymudder is offline
What's needed? T-5 5 speed to T-150 3 speed cjsabo Jeep CJ Forum 2 02-09-2010 07:56 AM
Can a 63' 3 speed be converted to a 4 speed jgrassw Jeep CJ Forum 5 08-17-2009 07:54 PM
85 cj7 3 speed or 4 speed auto? tbury85cj7 Jeep CJ Forum 6 03-10-2009 10:35 PM
3 speed to 4 speed J. Bubba Lee Jeep CJ Forum 4 11-17-2008 10:20 AM
3 speed vs 4 speed crawdad Jeep CJ Forum 14 05-16-2008 10:21 PM
