5 speed in a CJ? - JeepForum.com
post #1 of 55 Old 01-05-2010, 07:41 PM Thread Starter
Stroudcreek
5 speed in a CJ?
I am running 4.88 and 35's, in an 86 CJ7 with a T176. I have a 8.8 rear and a 44 front but I sure would like to have a 5th gear for the road. What would be a good 5 speed and has anyone put one in?
Stroudcreek is offline
post #2 of 55 Old 01-05-2010, 07:57 PM
scottymac62
1979 CJ7
Here's your puppy..........If you want to go 5 speed...go with this one..
The NV4500 Transmission - Novak Conversions
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 55 Old 01-05-2010, 07:59 PM
Area.3.Fiftyone
^^^ Just be prepared to open your wallet really wide.^^^
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #4 of 55 Old 01-05-2010, 08:03 PM
scottymac62
1979 CJ7
Oh yea...I forgot to mention that!
post #5 of 55 Old 01-05-2010, 08:11 PM
foggybottombob
I don't think you want an NV4500 unless you have a V8. For a 6 cyl I would suggest the NV3550 but it probably would not cost much less for all the adapters. I have a T5 in my CJ which everybody hates but I have not torn it up yet.
foggybottombob is offline
post #6 of 55 Old 01-05-2010, 08:30 PM
gojeepin
1983 CJ7
Originally Posted by foggybottombob View Post
...I have a T5 in my CJ which everybody hates but I have not torn it up yet.
Agree on the T5 being a good transmission for you. With 4.88s, you've transferred the stress of the driveline to the axle shafts... had you been running 2.73s,the greatest stress would be on the transmission, transfer case, and driveshafts.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #7 of 55 Old 01-05-2010, 09:01 PM
CJhollic
1980 CJ7
x3 on the T5. I have put a lot of miles on it with no problems. Like a previous poster said, it seems like everyone hates them, but mine keeps humming along.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #8 of 55 Old 01-05-2010, 11:38 PM
86cjjeeper
X4 on the T5. over 117,000 on mine and still going strong. people hate them, and they're claimed to be weak, but if you dont go romping on the skinny pedal everywhere you go, then i dont see it being a problem with 4.88's. although i run 4.56's and the skinny pedal is held to the floor multiple times during any trailride(running an '86 with a 258). the ability of being able to shift quickly if needed has gotten me out of some pretty sticky and offcamber situations. drive it right and a T5 should last. and if it doesnt, they are pretty cheap and simple to rebuild.
'86 CJ7-258-T5-D300 - D44/D30 4.56's w/ Truetracs F/R
and a few other doodads and geegaws
86cjjeeper is offline
post #9 of 55 Old 01-06-2010, 01:22 AM
only in a jeep cj
X5 on the T-5. I prefer them as I like they way they feel when shifting and the way the shifter springs back to center. Easy to find the gears and the overall gearing matches my driving style. I really need a 5th gear for interstate travel as my stockish CJ-7 sees higher speeds. I also picked up an AX-15 for a future project....we'll see.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 55 Old 01-06-2010, 11:56 AM
trailhead2004
1980 CJ7
X6 on the T5. I have one and love it. BTW, running 4.10 diffs. You may also want to look into the B&M short throw shifter. It really tightens the pattern up a lot.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #11 of 55 Old 01-06-2010, 01:57 PM
foggybottombob
Just FYI, the T5 comes in two versions. One has a 0.86 5th gear and the other has a 0.76 5th gear. That is a significant difference when it comes to chosing gear ratios.
post #12 of 55 Old 01-06-2010, 02:45 PM
trailridin4x4x4
1981 CJ7
i have a t5 behind a 4.0 mpi in a 81 cj7 w/4:56 gears and 35's it's perfect and i'm not worried about blowing it up 4.0's are torquey but not really enough to grande a t5
trailridin4x4x4 is offline
post #13 of 55 Old 01-06-2010, 06:10 PM
carldimery
1979 CJ7
why dont you consider the ax-15. This is a great tranny and it has an overdrive.You can find these very cheap, they are much stronger than the t-5, and it only cost $100 to adapt them to a dana 300.
carldimery is offline
post #14 of 55 Old 01-06-2010, 06:16 PM
foggybottombob
I've read a lot of "I rebuilt my AX-15 and it went out the next week" stories. I have no experience with them but a lot of people say the synchros quit on them a lot. I've run my T5 for several years with no problems and I bought it used from a junkyard.
post #15 of 55 Old 01-07-2010, 09:43 AM
Happy Joe
T-5s work and work well if applied and driven properly.
That said they were originally designed with a 100,000 mile life and most (survivors) are now well past their prime (probably need a rebuild). It should be noted that there are many different strengths and flavors of T-5 the one behind the jeep 6 was one of the stronger early ones (before the "world class"). The ones behind 4 cylinders were not as strong (break pretty easily) as they were designed for very low torque applications.
These trannies are well matched to low torque applications (6-cylinders of the 258 and 4.0 liter flavors) and short stroke (in the 3" range) v-8s if not abused. They do not typically work well for the younger drivers or behind medium torque engines (v-8s in the 350 cubic inch range, and higher).
I like mine it was abused nearly to death then pulled from a fellow Jeeper's garage many years ago (definitely needs a rebuild).
Recently though I have been looking at the NV-3550s.
I have a spare T-5 though and it has occurred to me that the long tail shaft might be replaced with a range doubler (low range gears from a NP-207) giving a low torque 6 or 8 speed (some gears would be too close together to count) with a first gear that would be lower than 10:1 (some machine work would be involved; I need to heat the shop, pull apart a 207 to measure its innards, get some milling machine tooling, and replace the motor on my lathe, first). (Back burner/someday project).
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
What's needed? T-5 5 speed to T-150 3 speed cjsabo Jeep CJ Forum 2 02-09-2010 07:56 AM
Can a 63' 3 speed be converted to a 4 speed jgrassw Jeep CJ Forum 5 08-17-2009 07:54 PM
85 cj7 3 speed or 4 speed auto? tbury85cj7 Jeep CJ Forum 6 03-10-2009 10:35 PM
3 speed to 4 speed J. Bubba Lee Jeep CJ Forum 4 11-17-2008 10:20 AM
3 speed vs 4 speed crawdad Jeep CJ Forum 14 05-16-2008 10:21 PM
