5 degrees positive Caster and still no center - Page 3 - JeepForum.com
post #31 of 42 Old 07-29-2013, 09:47 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
In theory simply spring-lifting a CJ shouldn't change caster, assuming the springs have the same eye-to-eye length as factory and you don't change shackle length.
Many of us have used YJ springs for our lifts because they are 2.5" wide in front and provide a better ride. However, the front YJ springs are about 1" longer then CJ springs. Therefore caster angle does change when using these springs.
My 2.5" YJ lift required 4 degree shims to get 7 degrees of caster. It tracks and returns to center beautifully with this setup.
Hope this helps,
Matt
Matt1981CJ7 is offline
post #32 of 42 Old 08-03-2013, 07:31 AM Thread Starter
robcoon
1981 CJ7
update
I have installed the 4 degree shim, and replaced the tie-rod ends. The original tie-rod ends were very worn and not keeping the toe end. While test driving the steering starts to return to center but not all the way. Plan now is to install a 6 degree shim and test again. Will post again after the new shim is installed.
robcoon is offline
post #33 of 42 Old 08-03-2013, 07:44 AM
skizriz
1978 CJ7
Did you ever check the ball joints as suggested? If they are too tight, having 20 degrees of caster won't return the wheels to center.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #34 of 42 Old 08-03-2013, 06:08 PM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Question: Can you have to much castor? Say you add 6 degree shims and now your at 8 degrees positive caster. Bad or good?
Guy Smilie is offline
post #35 of 42 Old 08-03-2013, 06:14 PM
LumpyGrits
YES, you can........That is even worst!
LG
LumpyGrits is offline
post #36 of 42 Old 08-05-2013, 09:58 PM Thread Starter
robcoon
1981 CJ7
solution
Ball Joints are okay. Tie-rod ends are replaced, Toe-in is fixed. 6 degree shim is in place. Final part of the puzzle: Steering box was too tight. Loosened the load on the steering box by 1/2 turn and the jeep centers after a corner. Thanks for all the help.
robcoon is offline
post #37 of 42 Old 08-05-2013, 10:23 PM
LumpyGrits
How much free play do you have in the wheel now?
LG
post #38 of 42 Old 08-06-2013, 05:48 AM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Did you or will you have a shop check your settings? Was wondering what your final caster reading is.
post #39 of 42 Old 08-06-2013, 07:28 AM Thread Starter
robcoon
1981 CJ7
Final caster is 8.2 degrees. Very little free play in my steering.
robcoon is offline
post #40 of 42 Old 08-06-2013, 08:47 AM
LumpyGrits
I would take some out.......
LG
post #41 of 42 Old 08-06-2013, 11:09 AM Thread Starter
robcoon
1981 CJ7
I was thinking that also. What does too much caster hurt? The front u-joint?
robcoon is offline
post #42 of 42 Old 08-06-2013, 11:13 AM
LumpyGrits
