4x4 trouble - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 4x4 trouble
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiClayton Off Road WJ Long Arm Kits!Clayton Off Road - JK Prototype Gas Tank Skid
Unread 04-09-2012, 03:50 PM   #1
turbonusse2
4x4 trouble
I've noticed that with my t5 tranny and transfer case that I can only get it into 2wd and 4 low. is there some way to adjust the linkage or how would I be able to get 4 high?
turbonusse2 is offline   Reply With Quote
Unread 04-09-2012, 04:07 PM   #2
iluvcowjuice
1979 CJ7
Which transfer case is it?
iluvcowjuice is offline   Reply With Quote
Unread 04-09-2012, 04:10 PM   #3
gosupes
Linkage is not adjustable but I would look under there while someone worked the level to see if anything was binding. There are two rails, one for the front axle and one for the rear. Don't quote me, I could be backwards, but I think for 4lo, both shafts are pushed in the case, pull one spot back for neutral, pull one more spot and only the rear axle rail moves for 2hi, one more spot the font axle rail moves giving you 4hi. Probably some obstruction or wear in the linkage to keep that front axle rail from engaging in high range.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA, 4.5" lift, Woody CV shaft and Tattons in front, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, trying to keep it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline   Reply With Quote
