4x4 not engaging on CJ5 - JeepForum.com
post #1 of 5 Old 01-05-2009, 08:54 AM Thread Starter
BigTroy
1977 CJ5
I just purchased this 77 CJ5 and I can not get the hubs to lock in for 4wheel drive can anyone help me with this?
BigTroy is offline
post #2 of 5 Old 01-05-2009, 10:05 AM
dwloop
1976 CJ5
How do you know they are not locking??
If you have turned them to the 4x4 marks and they do not lock (Check by trying to turn the U-joint in the knuckle for that side) then the sliders are probably just gummed up with old grease.
Remove the allen screws on the outside of the lockout, pull the selector straight out. Make sure the slider slides freely inside the lockout body, cleaning with brake cleaner if necessary, and then apply a light coat of white grease to lube them.
If that is not it, the springs may be bad and you will need to replace the units.
HTH
Dave
dwloop is offline
post #3 of 5 Old 01-05-2009, 11:29 AM
Bear-Olemiss
1981 CJ5
The exact same thing was the case with me. Old factory lockouts were bad, or so I thought. After spending cash on new hubs and them not working either I figured it out. Short stub axle was broke clean. That is how i purchased it, not knowing. Check your axles first. Pull off the differential plate and your tire (to make it spin easier, while in the air) and spin the axle by hand to see if it spins the gears....
BAIL! "Welder's have hotter rods"
Arc-Up Welding Inc.
Vicksburg, Ms
Bear-Olemiss is offline
post #4 of 5 Old 01-05-2009, 12:01 PM Thread Starter
BigTroy
1977 CJ5
thank you for your help and also is your a tremec 150 3 speed? Have you ever had a problem with it jumping out of 1st gear when you let off the gas? thanks Troy
BigTroy is offline
post #5 of 5 Old 01-05-2009, 09:59 PM
Bear-Olemiss
1981 CJ5
4 speed, sry
Arc-Up Welding Inc.
Vicksburg, Ms
T150 not engaging. Is it my clutch? tgram Jeep CJ Forum 15 08-20-2009 12:53 PM
Starter not engaging flywheel! trueprimitive Jeep CJ Forum 7 08-05-2009 10:05 PM
Starter not engaging NateCJ5 Jeep CJ Forum 4 03-10-2008 08:23 PM
Transmission not engaging? Clutch? PLEASE HELP fotophreak33 Jeep CJ Forum 6 11-24-2007 10:16 PM
clutch not engaging 81cj7mudder Jeep CJ Forum 6 11-20-2005 05:53 PM
