4WD indicator not turning off when in 2WD - 1983 CJ7 - JeepForum.com
post #1 of 5 Old 10-02-2013, 09:48 AM Thread Starter
Jagermeister78
1983 CJ7
Hello all, I'm new to the form. Brought my 1983 CJ7 (aka "the money pit") back to life over the last year.
So my question is: The 4WD indicator light just started coming on when it's not in 4WD. I cycle 4L, 4H, 2H and the light goes off for a few minutes and it comes right back on when driving in 2H. Is there a switch sticking somewhere? If so, where's the switch located within the linkage? Crawled under the jeep and couldn't figure it out. Do I need to access it from the tub?
Any help appreciated. Thanks!
Jagermeister78 is offline
post #2 of 5 Old 10-02-2013, 10:03 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It should be the only electrical connection to the transfer case.
My highly technical diagnostic procedure would be to wiggle the wire.
Matt
Matt1981CJ7 is online now
post #3 of 5 Old 10-02-2013, 11:15 AM
SuperSportCJ
1982 CJ7
Or check your 4wd switch. The little ball that pushes in when in 4wd may be stuck. Spray it with some sort of cleaner like WD-40 if possible to free it up. Check wires while you are down there.
SuperSportCJ is offline
post #4 of 5 Old 10-02-2013, 11:15 AM
SuperSportCJ
1982 CJ7
Switch should be on passenger side of T-case higher up on the casing near the shifter.
post #5 of 5 Old 10-02-2013, 01:24 PM Thread Starter
Jagermeister78
1983 CJ7
Thanks for all the info. Will try and tinker with it tonight! Joey
